can't read the dip stick....
Old Jan 8, 2007 | 04:11 PM
tylerdurden07's Avatar
tylerdurden07
Default can't read the dip stick....
This car has the crappiest dipstick evaaaaaaarrrrr!! First it's irritating to take out and even worse to put back in.., then I have to clean it off about 5 times just to get an accurate reading ( WHICH BY THE WAY WAS 2 QUARTS LOW AFTER 2000 MILES!!!!! ) First the EVO gave me issues, now this car is turning to a P.O.S. If this keeps up I'm going to take the mods off and F@#kin burn it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!
Old Jan 8, 2007 | 04:40 PM
NightRida's Avatar
NightRida
What do you expect? You do have the rev-"consumes lots of oil"-up motor in it!
Peace!
Old Jan 8, 2007 | 04:46 PM
glowz825's Avatar
glowz825
my 06' was down about a quart and 1/2, Then all of a sudden it stops consuming oil and there is no more black residue on my exhaust tips. So my consumption issue seemed to be a break in issue. The car now has 4500 miles and not one drop consumed yet
Old Jan 8, 2007 | 04:50 PM
tylerdurden07
Cool bro... Appreciate the response... Maybe mine will do the same of I'll be trading it in for a freakin TITAN..
Old Jan 8, 2007 | 04:52 PM
The guy who designed the dipstick committed hari kari . Its true. Look it up.
Old Jan 8, 2007 | 04:56 PM
tylerdurden07
I hope it was slow and painful!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 8, 2007 | 05:00 PM
LOL. Once at Jiffy Lube the guy got so frustrated that he handed me the dipstick. You put this damn mother flucker in!
Old Jan 8, 2007 | 05:18 PM
bailey bill's Avatar
bailey bill
Pull the dipstick slightly right and forward, then it comes right out.
Hold it in the same orientation to put it back in.
No problem.
bill
Old Jan 8, 2007 | 05:21 PM
deltaforce's Avatar
deltaforce
**** i will buy that 350z off you man at least you can say you got one
Old Jan 8, 2007 | 05:25 PM
stein's Avatar
stein
No problem.
bill
Except you're still not going to get a clean reading! I've thought about creating something that will at least allow a better reading.
hiz-n-herz's Avatar
hiz-n-herz
Sweet!... My z just stopped getting black residue in the tail pipes too. I have 4800 miles. But I thought it was the MREV2 and spacer leaning things out.
Weird thing is that my wife's 06z NEVER got any black residue on the tail pipes.
Old Jan 8, 2007 | 05:31 PM
jtabraham's Avatar
jtabraham
To get a good reading, make sure the engine has been off for an hour, if not you'll get a lot of residual oil. Take the stick out and wipe it off. Put it back in (without twisting), leave it or 1/2 a second and pull it out quickly. Immediately hold it horizontal so the oil doesn't drip too much. This has been the only method that has worked consistently for me.
FYI - Dip stick has been redesigned and improved for the 07 Z.
Old Jan 8, 2007 | 05:57 PM
Ztalker's Avatar
Ztalker
the dipsh!t dip stick is as old as the internal combustion engine itself....someone needs to make a digital monitoring system ASAP.
Old Jan 8, 2007 | 06:18 PM
Kam350z's Avatar
Kam350z
I am so so sorry about your dyno numbers. It must suck to put so much money into a car and have no pay-off in the end.
Old Jan 8, 2007 | 10:01 PM
Kf3's Avatar
Kf3
yeah they really are kinda bad, no offense. Have you reflashed your ECU?
Old Jan 8, 2007 | 10:18 PM
aren21's Avatar
aren21
You want a good reading?? Theres really only one way to do it. I let the car sit overnight in the garage (so its leveled), then in the morning I check it. If you just changed your oil, its still hard to see it, but after about 1k miles, it darkens a little so its easier to see. Good luck.
Old Jan 9, 2007 | 02:05 AM
imseksy's Avatar
imseksy
i would never take my Z to jiffy lube.
Old Jan 9, 2007 | 02:10 AM
zand02max's Avatar
zand02max
The 07's should be way easier, not sure if the dipstick is the same though!
Old Jan 9, 2007 | 03:18 AM
MasterRacer's Avatar
MasterRacer
LMAO you let Jiffy Lube do your oil changes ?????
Last time my friend did that they overfilled her Neon ummm wasn't
a good thing haha and yeah dipsticks a pain but accurate as I found out
and I too was running somewhat low on oil after 2500 miles. Iam doing the
oil consumption test now and will return to dealer in bout a month or so.
This is not a break in issue as my car has just over 9000 miles.
Old Jan 9, 2007 | 05:41 AM
Category5's Avatar
Category5
I've found that if you check it first thing in the morning, after the oil has settled, it's much easier to read. Go Gators!
