Real easy questions for base owners
Does the 350z base come with tire pressure monitoring sensors or whatever there called. The things that tell you the tire pressure in the three gauge pod. I've been curious for 3 weeks and I dont have my z too look. Im asking about 04.5 or 04 coupe base models. Thanks
there should be one or two buttons on the right side of your guage cluster.... start pushin the top one it'll bring you to the tire pressure..... well thats if it has it.....
All your base, are belong to us.
http://allyourbase.planettribes.gamespy.com//ayb2.swf
had to be said.
had to be said.
had to be said.
had to be said.
04.5 base does not have tire pressure monitoring.
The tires are also run-flats and you can't tell when the pressure is getting low.
That's why it's important to check and maintain your air pressure often!
Originally Posted by DJMatrix1067
i was under the impression this was standard on all Z's.
my 04 track has it.
my 04 track has it.
i have an 04 base im not sure if its an 04.5 though. i think it might tell you when your pressure is low. or if you put new rims on it might get messed up. my buddy has an 05 base and his has it. its messed up cause he put new rims on. but im not entirely sure on my Z.
