Do you guys drive when it is below 0 outside?
Old Feb 21, 2007 | 11:07 AM
Minda's Avatar
Minda
Default Do you guys drive when it is below 0 outside?
It is easy to notice that most of folks here are prbly from California or Florida enjoying sunshine and >60 degrees all year round, hence are not familiar with northern temps
Although my Z serves as a daily driver all winter, I never drove it in temperatures that low. I drove from the office tonight and it was 5 degrees (nice boost of power BTW). Tommorrow the temps are hitting 0 (-17 celsius)and may even go below that.
I run Motul 300V 5w-30 oil, which is generally ok for low temps.
Any experiences appreciated?
Old Feb 21, 2007 | 11:10 AM
AlvinHuyN's Avatar
AlvinHuyN
Nismo 370Z #697
If its freezing, I'm not risking driving my car. I totaled my last car driving in below freezing temperature and it was sunny out! Black ice is hard to see
Old Feb 21, 2007 | 11:35 AM
derek173's Avatar
derek173
I run my car year round, its 40 today but last week it was -1 to 2 degrees, no problems at all. All-season/winter tires are a must..... dont even think about going out in your performance summer tires.
Minda's Avatar
Minda
Actually, when it is that cold, the streets are dry as a bone.
I am more concerned with engine and moving parts wear/damage...
Old Feb 21, 2007 | 11:39 AM
tylerdurden07's Avatar
tylerdurden07
Yes.. I have no choice
Old Feb 21, 2007 | 11:47 AM
Lerxst's Avatar
Lerxst
I used to and had no issues with winter tires, except for the clearance. Now it's been put away till April.
Old Feb 21, 2007 | 11:55 AM
PerfZ's Avatar
PerfZ
Yep, year round unless there is snow on the streets. Let it warm up a bit (sleeps in an attached garage) and good to go. Stock tires suck in the cold though, be careful. I'm not aware that 0 degree startups are any worse than 32 degrees BTW, just no high revs until it is fully warm.
Old Feb 21, 2007 | 11:57 AM
Bobbo756's Avatar
Bobbo756
I believe the recommended temp range of 5w-30 in the 350z service manuals goes as low as -15 degrees.
Old Feb 21, 2007 | 11:59 AM
sofa king's Avatar
sofa king
weak! tuesday my car said it was -7.
Old Feb 21, 2007 | 12:22 PM
Minda's Avatar
Minda
Wow, Z in Alaska!
You may claim the Northernmost Z !
If your Z survives in Alaska, then mine shall be fine.
BTW, I only run on winter tires in winter, with a lot of slushy-snow days here it would be total carelessness to run summer or all season tires.
Old Feb 21, 2007 | 12:25 PM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
sometimes I'd rather take the Z in cold weather because it heats up quick and has heated seats. But usually the wagon is on call for duty in cold/rain/ice/snow.
Old Feb 21, 2007 | 12:32 PM
MiniRide's Avatar
MiniRide
I drive mine everyday.. Rain/Snow.. in NY
Old Feb 21, 2007 | 12:36 PM
Escobar's Avatar
Escobar
take a pic of your temp gauge when its in negative, i have never seen that in the Z
Old Feb 21, 2007 | 12:46 PM
Jim@Showstoppers's Avatar
Jim@Showstoppers
I drive a 90 Honda Accord with a weber Carb kit...pretty sick. We should have a "winter beater showoff".
Old Feb 21, 2007 | 02:21 PM
Swiffer's Avatar
Swiffer
Yep.
Old Feb 21, 2007 | 03:00 PM
HighwaySpeed's Avatar
HighwaySpeed
Talking
Originally Posted by dave079
0 degrees? Whats that?
+1
Old Feb 21, 2007 | 03:37 PM
Barmats's Avatar
Barmats
I live in Minnesota and drive my Z every day. Except when there's more than 3 or 4" of snow on the ground. The coldest I drove it in this year was -29 on the temp display. Below freezing, and when the engine is cold, the gearshift linkage is very reluctant to shift into 2nd (either up or downshifting). Once everything is warmed up, it's fine. I also run on a dedicated set of snow tires and wheels in the winter. To do otherwise in the snow is to invite certain disaster!!!
Old Feb 21, 2007 | 03:38 PM
Steve_03's Avatar
Steve_03
Yup I drive mine all winter it was -7 or so here last week. I just let it warm up for a few min. Also winter tires are a must, not just because of snow or ice, but because the summer tire compounds become like plastic tires under 30F or so and will have 0 traction on dry ground. Winter tires are much softer and keep their traction capabilities.
Old Feb 21, 2007 | 04:07 PM
bofa's Avatar
bofa
I wouldn't leave my house in 0 degrees much less drive the Z. Too cold for my blood.
