Can I fit 4 rims/tires in my 350Z?
I fit four 18's w/tires and four 17's with tires at different times....
no problem. take out your spare, remove the seat and voila! you put the two tires in the front standing up side by side and one in the rear will and one infront of the rear strut bar.
I started a thread and posted pictures back when I did it at 350zmotoring. same user name if you want to research.
Originally Posted by kwiker
No, you can't do it. If you pull the seat you can put maybe 2 max, but i bet only 1 and you can definately not fit anything between the strut and seat, any wheel and tire will be too tall to shut the hatch...and only one will fit the spare tires area, you can't stack two up, hatch won't close.
totally wrong, along with the other people that said you cant do it. Ive fit 4 17's with mounted tires and 4 18's with mounted tires on seperate occasions with the passenger seat in the car and the spare out. obviously 19's wil be a tighter squeeze
275/35R18 Hoosiers: Take out rear carpet and spare tire, one tire/wheel in the spare tire well, one ahead of the rear strut bar, two in the passenger seat area (one behind the seat, one in the seat, or both in the seat). I was able to get the spare back in on top of the tire in the spare tire well, but it was really tight.
Same thing for the 285/30R18 V710, although there was no way to get the spare tire in, and there was barely enough room to get the tire in front of the rear strut bar in and out -- as long as the tire was warm.
You can do it. Just stand two up in the front seat. Put one in the hatch in front of the sway bar, the other will fit behind the sway. You may even be able to close the hatch.
I did this with two 19's in the front seat and 2 20's in the hatch w/ no problem.
Just make sure you put a blanket over the interior pieces and you'll be fine.
Originally Posted by drivenCSZ
idiots...all of you. why say, no you cant do it, when its obviously been done atleast 4 times before by myself and motormouth.
Ok, Mr. Einstein... Go and do it for him then...
EnjukuRacing
Sep 11, 2015 08:30 AM
