How bad are the Z's blind spots and rear window visibility?
Old May 4, 2007 | 11:00 PM
The Brickyard Rat's Avatar
The Brickyard Rat
Imo, the views backwards out of the Z are less than ideal. But if my 64 year eyes & bones can get used to it, you surely can!
Worse situation is backing out of a parking spot with cars on either side. Therefore I back into parking stalls & pull out facing forward.
I'm 6'2".
Old May 4, 2007 | 11:06 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
the rear window takes a little getting used to as you dont have the amount of visibility you would with MOST other cars. you pretty much see the road behind you and all the way back....not much sky. but once you get used to it, it's better. with the rear, what bothers me more is the fact that anything you might have in the back is reflected up into the window.
as far as blind spots go... there are none if you adjust your mirrors the right way. granted, i'm five two so i dont know how useful this is to you but what i did was sit normally in the car, adjust the mirrors so that the inner edge is just barely reflecting the car, then turn then even more outward than that. you should have to lean forward to see the cars reflection. so the range of sight you get between your normal seated position and the leaning forward position pretty much covers all blind spots.
i have no idea if that made sense but basically, anytime i wanna change lanes i scope out the lane in the rear view, look in the side, lean forward to make sure i'm not missing anything, lean back again and change. no blind spots, yay.
Old May 4, 2007 | 11:08 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
I'm 6'2".
+10000000 on that one... i despise backing out of a spot
Old May 4, 2007 | 11:45 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
A big + 1 on that!!!! Also the amusement factor watching someone being stunned that you're backing into a carpark when they've just struggled to go forwards into their carpark. lol
Originally Posted by MeetJoeAsian
how bad? I think worse than most car...but you learn to adapt...
The one thing to remember is it's a sports coupe so the rapier of the roof line is different to your average family sedan. I personally don't think the potential lack of visability is any worse than any other sports car/coupe. As Joe says, adjust your mirrors in the right place, and problem just about disappears.
Old May 4, 2007 | 11:49 PM
evolved326's Avatar
evolved326
I find that my third eye helps, especially in drive-throughs where the menu is behind the order area, at mcdonalds on king and mclaughlin.
Old May 4, 2007 | 11:57 PM
Originally Posted by camaro194
Good deal. As long as you adjust the mirrors correctly, you shouldnt have a problem. It also depends on what kind of car you are coming from. The view out the back is kinda limited distance wise (noticeable on the freeway), but the side mirrors help a lot.
+1. 50,000 miles and no incidents. The right outside mirror covers the entire right side of the car. Trust your mirrors.
Old May 5, 2007 | 12:15 AM
Armitage's Avatar
Armitage
I don't find it that bad. You really can't look over your shoulder to check your blind spot (no windows) and your rear view is somewhat limited, more vertically than horizontally.
Other than that, it isn't that bad at all.
Old May 5, 2007 | 12:19 AM
Nexx's Avatar
Nexx
better then my 98 ss camaro. just dont be newbie and you will be fine.
Old May 5, 2007 | 12:29 AM
gsazabi's Avatar
gsazabi
They're pretty bad at night especially with dark tint. I got used to it so it's no problem now.
It's better than blindspot on my friend's s2k. Man that car has some NASTY blind spot.
Old May 5, 2007 | 12:34 AM
Eazzy's Avatar
Eazzy
For what its worth, if need be, I use my electric mirror switch and swing the mirrors sideways or up and down to get a better view of whats happin'in if Im in interstate, congested, higher speed, lane changing, specially if Im doing a merge entering the Hi-Way
Old May 5, 2007 | 12:40 AM
Demon Z's Avatar
Demon Z
The blind spots on the Z are the worst ones on any car that I've personally owned, but the way I see it, it forces you to be careful... there's no substitute for using your mirrors and looking over your shoulders when maneuvering.
Old May 5, 2007 | 01:43 AM
zpak's Avatar
zpak
Originally Posted by kh_08
They're bad, but I have no prob since I added the little concave mirrors to the sides
I think you mean "convex", but that's just me being picky (sorry).
(concave = image upsidedown)
Old May 5, 2007 | 01:45 AM
zpak's Avatar
zpak
Yes, the rearview visibility is compromised in the Z compared to other cars, but you can compensate for this with aggressive/vigilant rearview surveillance. You just have to ask yourself...do you love the Z enough for this extra "work"?
(for me, the answer was easy: "of course")
Old May 5, 2007 | 04:15 AM
r0mey's Avatar
r0mey
in a roadster with the top up they are very bad VERY BAD!
Old May 5, 2007 | 05:31 AM
DavesZ#3's Avatar
DavesZ#3
Yes the Z has bad blind spots, so do most all sports cars.
There is a simple and effective solution though - the proper adjustment of your mirrors and learning to use them:
http://www.motorists.com/issues/safe...t_mirrors.html
It take a week or two to get used to them but once you do you'll wonder how you ever got by without this method.
Old May 5, 2007 | 06:13 AM
exchange240sx's Avatar
exchange240sx
I agree that it is worse than most cars I've driven/owned, but it doesn't take long to adjust to.
Old May 5, 2007 | 07:14 AM
Mid117's Avatar
Mid117
I came from a camaro, so I'm used to nasty blind spots.
You get used to it though
Old May 5, 2007 | 07:18 AM
  #38
SuperBlack350z's Avatar
SuperBlack350z
i think its not bad at all.
Old May 5, 2007 | 07:35 AM
  #39
djnc's Avatar
djnc
relative to other cars, the Z's rear visibility is horrendous, but it doesn't take long to get used to...its not like you'll back into something because of it
Old May 5, 2007 | 07:39 AM
  #40
Sunset350ZR's Avatar
Sunset350ZR
+1 but 90% of the time the roof is down so hardly ever a problem.
