How well does your cruise control work?
Old May 7, 2007 | 11:20 AM
billp's Avatar
billp
Default How well does your cruise control work?
I searched but didn't find anything.
First time Z owner, 2004 Touring Coupe.
I noticed that on a slight downhill that the cruise doesn't hold the speed, is this what you guys have found or is it in need of repair. "going" it works fine, but when going downhill it picks up speed.
Old May 7, 2007 | 11:24 AM
zstreet86's Avatar
zstreet86
depending on going up or downhill, it varies + or - 2 mph
Old May 7, 2007 | 11:25 AM
Anomaly's Avatar
Anomaly
+1
I think the largest deviation I've noticed has been about 3 mph.
2004 Touring
Old May 7, 2007 | 11:27 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
That's normal. When on the flat the LED, analog display, and my GPS are all within 0.2 mph when sailing along at 80 mph. Going down a steep downhill all the cruise control can do it lower the RPMs to idle - it doesn't work the brakes.
My Xterra has a downhill assist which actually works the brakes to maintain speed going downhill. It uses the ABS abilities to brake the tires one by one as needed to help you crawl downhill.
Old May 7, 2007 | 03:36 PM
billp's Avatar
billp
My Honda van will maintain the speed up or down a reasonable hill, actually, I don't think that I've ever 80K miles needed to "help it" with the brakes.
With the Z, I have mostly done in town driving, and noticed that any "downhill" situation and it will go up 3-5 miles, at that point I applied the brakes. Yes, being an old fart, I use the cruise all the time, tend to have a heavy foot.
Old May 7, 2007 | 05:07 PM
keosh's Avatar
keosh
cruise controle is fine like others said largest difrence was 3 mph
Old May 7, 2007 | 05:11 PM
halfass872's Avatar
halfass872
I'd die without my cruise control!!!!
Old May 7, 2007 | 05:18 PM
stein's Avatar
stein
We have cruise control?
j/k, with all the traffic here I haven't got a chance to use it much.
Old May 7, 2007 | 05:34 PM
HighwaySpeed's Avatar
HighwaySpeed
Thumbs up
Mine works well!
Old May 7, 2007 | 06:09 PM
Plus or minus 2 MPH. I dont use cruise control on a mountain road.
Old May 7, 2007 | 06:11 PM
Zmazing03's Avatar
Zmazing03
I use cruise almost daily.
Uphill its fine, but I find going downhill, it gets on my nerves with the little "jolt" it does, if you will. I just tap the clutch or brakes and coast down the hill -- holds its speed more comfortably.
_bit
Oct 2, 2015 07:49 AM
