Shifting
Old May 23, 2007 | 05:25 PM
smartparts15's Avatar
smartparts15
Yea it does haven't you ever seen 2F2F!??!?! :P
Old May 23, 2007 | 05:28 PM
Nexx's Avatar
Nexx
Originally Posted by Alberto
I rev match as far down as 2nd then come to a stop. Im always in 1st when stopped, never in N.
lol, i expected no less from the all mighty destroyers of trannies.
bert > transmissions
Old May 23, 2007 | 07:37 PM
Korki Buchek's Avatar
Korki Buchek
Why would you rev match into a stop? Shouldn't you be breaking and letting the engine speed slow down?
Old May 23, 2007 | 07:53 PM
dikspiel's Avatar
dikspiel
Chestons Toilet
rev matching to stop? that sounds like a pain in the ***..
I put it in neutral and coast or neutral and break. then i put my stunna shades on.
BojanC350z's Avatar
BojanC350z
warenty...i downshift
Old May 23, 2007 | 08:48 PM
roast's Avatar
roast
for those of us who have been shifting gears practically our entire lives... downshifting/revmatching is no big deal and second nature.... along with heel-toe downshifting
I would not recommend rowing through every single gear tho, that is unnecessary unless you're road racing/raging.
Coasting in neutral is noobish... unless of course you're roughly at or below 15mph and finishing off a stop. Engine braking saves gas and gives you more control over the car should you need to accelerate or maneuver. Just don't lug the engine by letting the RPM fall too low while in gear. A typical scenario is 6th > 3rd > neutral....
Once at a stop it's best to be in neutral and release the clutch pedal so you don't put unnecessary wear on the throwout bearing. It's not good to keep the clutch pedal depressed for extended periods. When it's almost time to accelerate push the clutch in and wait for the tranny to stop spinning... then select 2nd then first...
Old May 23, 2007 | 09:04 PM
Zmazing03's Avatar
Zmazing03
I do 6th > 3rd > 2nd > neutral. The Z really does not slow down too much in 3rd gear. 2nd gear is where the engine braking is best.
Almost, but not quite. I can easily do the former without even thinking about. Not so much the later.
Old May 23, 2007 | 09:14 PM
chriskabobbers's Avatar
chriskabobbers
Originally Posted by z32 Outlaw Z
put it in reverse
ROFL!!
Old May 23, 2007 | 09:21 PM
myZter's Avatar
myZter
PREMIER MEM.FTW
i press the brakes
Old May 23, 2007 | 09:30 PM
roast's Avatar
roast
yeah but most of the time... by the time you get close to idle in 3rd downshifting to 2nd isn't necessary.... there are many variations... none really right or wrong...
Keep practicing.
If you're really good at revmatching, it doesn't take much to realize heel-toeing is just an extension of that.... nothing changes except the fact you have your foot on the brake and you blip the throttle with the side of your foot..... it's still basically the same exact thing.
Old May 23, 2007 | 10:17 PM
FALLEN1z's Avatar
FALLEN1z
im with the rev matching crowd. i do it without really thinking about it. usually i downshift to fourth and engine brake down to about 1500 rpms and put it in neutral. plus i like the sound of engine braking. i never scream it while engine braking.
at lower speed roads (25-35mph zones) i just downshift it one gear from what i was cruising in
Old May 24, 2007 | 03:21 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by smartparts15
IMO, brakes are cheaper then a tranny, im in neutral most of the time when comming to a stop.
You guy should be ashamed to think like this and own a Z. A proper rev match isnt hard on the tranny, its very smooth, and a proven way of slowing down. Keep on popping N when coming to a stop grandma...
Old May 24, 2007 | 03:22 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Rev matching is not heal/toe-downshifting/braking you know
Old May 24, 2007 | 04:16 AM
Apanther's Avatar
Apanther
neutral and coast for me
Old May 24, 2007 | 04:19 AM
gregtotheb's Avatar
gregtotheb
i downshift.
Old May 24, 2007 | 04:48 AM
smartparts15
Alberto Quote:
Don't own a Z.... yet.... 01 eclipse GT, All that I was saying is its more fuel efficient to put it in neutral and every time you use your cluth it still causes wear on the throwout bearing/tranny/clutch, but by all means do what you like to do, if you enjoy down shifting go for it, where I live now there is no one to impress usually, just empty roads, which are fun... but really its pretty much personal preference.
Old May 24, 2007 | 06:02 AM
ZBigDog's Avatar
ZBigDog
Downshift once, to third or second, depending on speed, then neutral and braking.
Old May 24, 2007 | 06:46 AM
  #38
Viffer35Z's Avatar
Viffer35Z
I downshift to 3rd at around 40mph which is about 2500 RPM and let it come down to 1200-1500 and go into neutral, at which point the car is going pretty slow.
Old May 24, 2007 | 07:11 AM
  #39
Get_Zwole's Avatar
Get_Zwole
if im coming to a stop light i just clutch in neutral and sit at the light till its about to turn green then i throw her in first and off again.
Old May 24, 2007 | 08:17 AM
  #40
MJM Z's Avatar
MJM Z
Very helpful, thanks. Just curious though, why put it in 2nd, then 1st? Why not just right into 1st? I'm sure it accomplishes something, what is it?
