Manual start question
Old Apr 30, 2003 | 06:48 AM
jleighZ's Avatar
jleighZ
Default Manual start question
I have been practicing a lot driving my car, and I do excellent in the driveway getting out of first. Problem is that when I actually get out in traffic I kill it I thought I would try starting out in 2nd gear yesterday and it worked perfect. Would it be ok to keep doing this until I get more comfortable starting in first, or will it hurt the transmission? I can do everything really good except that bloody first gear
Old Apr 30, 2003 | 07:32 AM
zwindsor's Avatar
zwindsor
Twisty addict
If you can start out in second gear then there shouldn't be any reason why it's a problem in first gear. You have to use higher revs to start in second which means your having to slip the clutch adn can cause undue wear.
Find a large empty parking lot and practice....practice....practice. Either your letting up the the clutch too fast or not bringing the revs up high enough.
You can do it girl!
Old Apr 30, 2003 | 08:02 AM
91na's Avatar
91na
On the other hand, if you can start in 2nd - and keep practicing on first - it's a lot better then killing it repeatedly in traffic.
Old Apr 30, 2003 | 08:05 AM
jleighZ's Avatar
jleighZ
First just seems too low of a gear to start it in for me. But I'm pretty proud of myself, I have learned everything else quite quickly
Old Apr 30, 2003 | 08:20 AM
zwindsor's Avatar
zwindsor
Twisty addict
Once you get rolling it's pretty straight forward from there. Wait until you have to stop on a hill though
Old Apr 30, 2003 | 08:34 AM
jleighZ's Avatar
jleighZ
haha, I am avoiding all hills right now My aunt told me I can practice on her road though this weekend, so I am going to try that Just gotta use the alternate route now to get to the place where I tan
Old Apr 30, 2003 | 08:58 AM
zwindsor's Avatar
zwindsor
Twisty addict
WHAT?? No sun in MO
Old Apr 30, 2003 | 09:10 AM
91na's Avatar
91na
We never get sun in Missouri, sometimes it LOOKS like the sun is up there but we know it is really just all of that humidity getting us overheated and making us see things
Sometimes, it looks like it is up there because yesterday was -10 degrees and today is 70.... just messes with your mind.
Old Apr 30, 2003 | 09:24 AM
jleighZ's Avatar
jleighZ
All the mosquitoes block the sun
Old Apr 30, 2003 | 09:40 AM
zwindsor's Avatar
zwindsor
Twisty addict
Man, those must be bug suckers Just think tho, now you can outrun 'em in your hot Z
Old Apr 30, 2003 | 09:42 AM
91na's Avatar
91na
Forgot about that... when they are not blocking the sun they are swooping down, picking you up, and flying off with you since they are so big.
Old Apr 30, 2003 | 09:49 AM
The Brickyard Rat's Avatar
The Brickyard Rat
Starting in second gear is not preferable by any means; you are "lugging" the engine. So get comfy with first as soon as you can.
Old Apr 30, 2003 | 11:16 AM
Anyone2u's Avatar
Anyone2u
Charter Member #82
haha, I am avoiding all hills right now ...
I'm sure everyone has given you advice on learning to drive a standard, but just in case no one mentioned it, when you do encounter a hill you can always use your handbrake as a brake since you (more than likely) don't have three feet. Just lift the handle up and hold the button in and as you take off, slowly put the handbrake down. This will keep you from rolling back into the car behind you. Doing it the normal way (taking your foot off the brake and quickly stepping on the gas) you might "overcompensate" for the hill, floor the accelerator and hit the car in front of you (bad). Then again, if no one is in front of you, you might execute an impressive burnout (good)!
Old Apr 30, 2003 | 12:20 PM
zwindsor's Avatar
zwindsor
Twisty addict
That's one way to keep visitors from driving through MO
Old Apr 30, 2003 | 03:19 PM
WayneTN's Avatar
WayneTN
My $0.02. When you get into real traffic, don't rush the takeoff just b/c someone is behind you. Concentrate on what you are doing and you will not kill the engine. So what if they have to wait an extra 2-3 seconds.
Practice on some hills, both with and without the handbrake.
You will get better as time goes by. By June 1 you will be an expert - trust me.
WayneTN
Old May 1, 2003 | 06:06 PM
fresno350's Avatar
fresno350
Default omg
omg your first manual car was a Z? wow that was smart. good luck
Old May 1, 2003 | 06:10 PM
ares's Avatar
ares
Veteran
hey you gotta do what you gotta do, what other option was there, buy a car for a few months to learn on? then she probably couldnt afford the Z. learning on it and possibly killing the clutch is only a few hundred $ mistake, less than a trainer car.
Old May 1, 2003 | 06:16 PM
Silver Bullit II's Avatar
Silver Bullit II
Default Feel of the engine
Every clutch/engine/torque curve being different, it helps me to drive with the radio/CD off to hear the engine, until I become accustomed to the clutch. I wouldn't be worried about the clutch, that's easy to have replaced. JMS in TX
Old May 2, 2003 | 12:51 AM
Zboy's Avatar
Zboy
Default Re: omg
Z is my first manual car too. I dont understand why some people here make a big deal at Z being first manual car for someone. Its a car, not a space ship. IMHO, Z is very friendly to learn how to drive manual in. It seems the clutch in Z engages in a "range" instead of one point and this helps the newbies. Took me 1 day to learn and I am doing fine and dandy now. No problems at hills, I am somewhat ok at rev-matching and will start woking on heal and toe technique soon.
Old May 2, 2003 | 04:39 AM
jleighZ's Avatar
jleighZ
Default Re: omg
What an intelligent post. Yeah I wanted a stick so what? Many, many others have got this car and it was their first time with a manual.
I'm doing so much better now. I'm going to practice with it the most of the weekend just to improve on a few things.
