Gas mileage...
Originally Posted by Scribl3
i have gotten up to 37mpg when cruising the freeway at like 75.
Thanks for all the replies guys
Well, I dropped her off today at dealer to get ck'ed out. The guy called back and said I had a dirty air filter and that might be the source of awful mileage.....they'll check into it some more and give me a call back. Where do they find these front desk service guys.....he tried to tell me initially that 162 mi using ~2/3 tank was perfectly normal!
Originally Posted by mackie24
just used up my first tank of fuel in my 350...got 22 MPG with city and highway driving...got 360 miles to the tank.
Its a 20 gallon tank. If you get 22 MPG, you would get 440 "miles to the tank".
bill
yea, i think is your commute, b/c before i used to have a 3 mile commute that took like 10 minuts max, and yea i got below 20 also, i think it might have to do with the fact that engine isnt able to warm up or something like that, because when i went back to long commutes that were even mostly city i got at least 20+, and yea, one time i got 44 mpg !!!!!!!! yea, i drove 50 mph the whole way on cruise in 6th, so it was pretty cool
whoo maybe i getta get a tune up for my car. I reset my computer the other day to see how much im averaging in the city (I live in NYC). Believe it or not, i was avging 11.8 MPG and 9MPH. Doesnt seem normal to me
Has anyone ever noted the optimum speed for the best gas mileage in a Z? If one were to drive a a constant speed, it seems reasonable to think that one would get a better mpg figure at 65 mph than 85. However, in informal tests, my 6MT seems to get a better mpg figure if driving at a constant 70 mph than it does at 50 mph. In the olden days of Jimmy Carter, the feds set the maximum speed limit at 55 mph because it was presumed to offer the best mpg. However, my Z doesn't seem to excel when driven in the 55 mph range.
I get consistently the best mileage when I'm able to hold it steady at somewhere between 60 and 65. This doesn't happen very much though, too much stop and go, or at least stop and slow way down, on the Beltway. Between DC and the OBX there are stretches when I can keep it slightly north of 60, and the mpg figure steadily creeps up as I check it during that part of the trip.
I get about 21mpg too work, mostly city crap streets and i drive pretty hard too, i have gotten 30mph dring to Chicago. as i modded the car i watched the MPG get better and better.. HFC's seemed to be the biggest diff..
I get around 18/19 mpg in city driving in my 2003 DB Track. When I drove frm MD to CA in 2003, I averaged 28.5 mpg at a steady 80 mph (using the cruise control). Otherwise, on highway driving not using cruise control and at lower speeds, I get about the same.
It could be that, once the car is broken in, that you will get better gas mileage.
Well, I dropped her off today at dealer to get ck'ed out. The guy called back and said I had a dirty air filter and that might be the source of awful mileage.....they'll check into it some more and give me a call back. normal!
Again, I wouldn't expect very high mileage from the description of your commute. You'd be lucky to get 20 mpg.
Originally Posted by cwerdna
Did you buy yours new? If so, unless you've been through a dust storm, it's extremely unlikely an air filter could get so dirty within a few weeks to cause really bad mileage. Dragging brakes, low tire pressure and bad alignment can hurt mileage.
Off topic a bit, but since you bring up dragging brakes....I've been having trouble getting used to braking with her...seems like regardless of how slow or fast I come to a stop, there is still a "brake catch" noise. Don't how to describe it....not really a grinding...just the noise you hear sometimes when you let off the brakes. Is this familiar at all to anyone?
I've played with getting the best mileage (based on the on-board computer) and today was the best yet. I was lock onto 58MPH via cruise control coming down MD Rt 29 this morning at approximately 8:30. I hit the reset button and after it did it's thing it reported 42.3MPH. I know that's a short term best case basis but all the same it makes you feel pretty damm nice.
Ed
Ed
