Runnin Slightly Higher RPM's
I noticed today that my Z is running slightly higher RPM's. It used to run at around 2800-2850 rpm's at 75 mph and now its running closer to 2900-2950. Any ideas as to whats up with that?
Tire pressure is less than the original test.
Weather conditions are different: temperature, humidity, barometric pressure.
You put on 100 pounds.
The relationship between engine speed (RPM) and vehicle speed (MPH) is determined by the tranny/differential gear ratios, and cannot change.
If you actually note a difference, then the problem has to be either in the tach system or the speedometer system.
bill
bill
Originally Posted by davidv
There is more gas in the tank than the original test.
1/4 of those could lead to the answer.
like the other guy said, its a mechanical link. Adding wieght or fuel would only slow acceleration, but at a given speed/gear the rpm will be the same.
such a small change could be caused my a low tire pressure or bad signal.
bill
bill
bill
bill
Originally Posted by Wheelman
On an automatic, a slipping torque converter can do this.
bill
bill
Originally Posted by roast
You're forgetting that ratio is directly affected by tire diameter, which can certainly change.
But the ratio between indicated speed and RPM is fixed.
You could put on bigger tires, smaller tires, or jack it up take the tires off, and the speed reading will not be affected.
bill
Nope same size rims and tires since Ive had the car. It just started doing this about a week ago.
Just something to randomly throw out there, I put that fuel system cleaner in my car, then exactly one tank later my girl puts another one in without my knowledge, how would this affect the car?
You probably need to have it driven by a Nissan tech with a scan tool to see if the torque converter is locking up when it should. With the same size tires and wheels, automatic, you should have the same speed @ rpm in gear as every other Z out there with the same tranny and final drive ratio. Confirm this number for sure to verify you actually have a problem, and if you do, torque converter issues, or leaky injectors are the only things I can think of that might cause that, unless its tachometer or speedo error. A scan tool should be able to verify this as well, by checking actual RPM and MPH against what the tach is showing. If not that, then for tranny issues; How many miles on the car? What does the transmission fluid look / smell like, and has it ever been changed?
Should I take it into a dealership to change the tranny fluid?
Originally Posted by Bailey Bill
The ratio between actual speed and RPM will change with tire diameter.
bill
bill
