07 0-60?
Old Aug 30, 2007 | 06:44 AM
07-Zman's Avatar
07-Zman
07 Z - 5.1 to 5.2 zero to 60.
Old Aug 30, 2007 | 09:15 AM
ZLadie2000's Avatar
ZLadie2000
Originally Posted by MC
the 5.1 was from edmunds.com on the nismoZ. it has no HP gains over the other 2007's
No nismo exhaust??
Old Aug 30, 2007 | 09:55 AM
Vorais's Avatar
Vorais
Originally Posted by JunkStory
I never tested it but I my friend did a couple of run in his stock Automatic 2006 Z and 0-60 was in the low 6's .. much slower than the 5 second of the 2006 MT Z (contrary to original belief)
Just curious, what altitude are you at? I live here near Denver, CO at 1.6km above sea level and cars here run much slower (especially NA ones) due to lower air density.
Old Aug 30, 2007 | 11:22 AM
Sea Bass's Avatar
Sea Bass
0-60 is too variable, and not the greatest indicator of performance. The 1/4 mile is the real standard, and that's where I believe the improvements to the 07 really show through over my older, beloved 03.
Old Aug 30, 2007 | 11:24 AM
Bumpinjeep's Avatar
Bumpinjeep
1/4 on the 07 stock are about 13.1-13.3. Better tires will give you better times if that is your sort of thing.
Old Aug 30, 2007 | 06:29 PM
HDPDZO6's Avatar
HDPDZO6
Curious as to where you got those quarter mile times, considering the best posted time for a STOCK '07 is 13.354. I realize the individual complained of a sticking clutch, however, that's the best time posted.
Old Aug 30, 2007 | 09:02 PM
VeeTec's Avatar
VeeTec
well also on the 5.1 0-60 on the same day they for 13.6 @ 103 out of that same nismo Z
so im thinking 13.3 would produce a a high 4.9-5.0 0-60
i think 13.1-13.2 on street tires is unlikely
Oh, it's going to happen.
My last trip was to a very slow track, for the SE, and I managed a very good time there with a bad DA. Take off the usual 3-4/10ths and add 1-2 mph at the faster tracks here, and I would have run very low 13's in the heat.
I imagine more people will be posting low 13's soon enough, as there just aren't very many 07's at the track really. Once it's cooler, it will come even easier.
Old Aug 30, 2007 | 09:05 PM
SniperHunter's Avatar
SniperHunter
that was before the rev up
the 2006 G's had 298HP vs the Z's 300 so basically marketing. under the new ratings the 298/300 motor went to 293
only the automatics still had the non rev up motor
the original 287 motor i think would come out to be around 279-280HP
The thing is, our Z engine is actually tuned slightly different than the Infintis. Infinitis can run 87 in their cars, and we can't. 06 intakes on Zs also helped prevent the car to get re-rated. And, of course, we have slightly different exhausts than the Gs. I'm sure there's some other little things too. Add all of that stuff up, and it very likely keeps our Zs at 287 crank.
Plus 240WHP dynos also prove that much. 15% drivetrain loss = 287CHP. Where as I've seen FX35s and G35s dyno 230-233WHP and that brings them to almost exactly 275CHP. =)
Old Aug 30, 2007 | 09:31 PM
Archbishop's Avatar
Archbishop
the 2007 Z has about 13 more HP than a 2006. Nissan switched to SAE ratings for 2007. so under the same ratings that rated the 2006 300HP it would have been about 313 for the 2007 Z
or to put it another way if the rev up 300HP motor came out in 2007 it would have been rated at 293 not 300. for example go look at the HP rating on the 2007 G35 coupe
The Z actually does have 2 more hp than the G35...
Old Aug 30, 2007 | 10:04 PM
BigRez's Avatar
BigRez
the 04 z is by far the fastest z ever made
Old Aug 31, 2007 | 05:03 AM
Go to the dragstrip, and post your time slip. Magazine racing is for fairies.
Old Aug 31, 2007 | 12:24 PM
zpak's Avatar
zpak
I think people are just quoting times for the Z that have been obtained by various other drivers (that happen to publish in magazines).
No one is claiming that they themselves can drive a Z to a 5.1 (or whatever) 0-60 time. Similarly, if I post a time slip time of 15 or 16 seconds for the 1/4 mile, does that make the Z a 15-16 second car? (nope...) People here are just referring to quoted numbers, that's all. Nothing "fairy" about that. And unless I'm a billionare and have the money to drive every single car under the sun, I'll have to turst the "magazine racer" when they tell me that they can get a 997 Turbo to do th 0-60 sprint in 3.2 seconds or the Bugatti to do it in 2.8.
Old Aug 31, 2007 | 12:32 PM
JCat's Avatar
JCat
Here is a car that will go 0 - 60 in 3.7 seconds.
Old Aug 31, 2007 | 12:57 PM
HDPDZO6's Avatar
HDPDZO6
Mine can do it in 3.9
My best has been a 4.2 in it though.
Old Aug 31, 2007 | 03:32 PM
  #38
KingOfV6's Avatar
KingOfV6
Wow 3.7 seconds, that is of course the same as the C6 z06 vette, I wonder which car has the faster 1/4, damn i bet its really close when this 08 viper hits the road the vette will be head to head for king of the road...that is of course excluding the current 911 turbo which is the fastest.
Does anyone know the 0-60 on the 05 35th anniversary Z, it has the rev-up and its the lightest rev-up Z, im sure it would be a close race with the 07
Old Aug 31, 2007 | 04:03 PM
  #39
D3VIL-Z's Avatar
D3VIL-Z
i got a 5.2 on a g-tech stock 07 base model if that helps
Old Aug 31, 2007 | 04:13 PM
  #40
The Cameron's Avatar
The Cameron
the 0-60 on the z06 is actually 3.9, and the viper is a hair faster in just about every category, as per the comparison in my C&D for this month.
