Please help.z stuck
Old Jun 27, 2003 | 10:57 AM
grogsnorf's Avatar
grogsnorf
Default Please help.z stuck
change air filter to k&n.......drove down the street.z died
disconnected battery.then reconnected.unable to turn key or roll windows down now
need to get it out of middle of road.............what can i do/
please reply
thanx
grogs
Old Jun 27, 2003 | 11:16 AM
wren57's Avatar
wren57
augh thats awful. have you tried replacing the k&n with the stock air filter? ok I just read its manual... hmm what does it sound like when you press the clutch and turn the key? any noise?
Old Jun 27, 2003 | 11:26 AM
grogsnorf's Avatar
grogsnorf
i put the stck filter back.was able to turn key.....push it off the road...now it wont kick.................right when it first died i punch it.........hesitated in like turbo kick.then just cut out.hasnt started since............and its very hot am so am i.will the dealer come and get this thing.......6k miles
Old Jun 27, 2003 | 11:53 AM
mark350's Avatar
mark350
Definetly call the dealer...I dont understand how an air filter would cause any problems like that. An air filter in the stock air box should be a item that causes no problems at all.
Old Jun 27, 2003 | 12:53 PM
350zdanny's Avatar
350zdanny
The only thing I could think is if you took out the mass air sensor and touched it wrong. Even a finger print can **** those things up.
Side story. I was changing the ABS sensor on my Accord and the damn thing is stuck in the wheel, so I did what anyone would do and pulled it until it broke. Now half the sensor is in the wheel and the other half is in my glove box. Moral of the story: Let the dealer fix it.
Old Jun 27, 2003 | 02:14 PM
grogsnorf's Avatar
grogsnorf
paid for the flat bed.it was sad.dealer said if problem under warrenty he will pay for the tow.thanx guys will let u know what up
Old Jun 27, 2003 | 02:31 PM
Duflacci's Avatar
Duflacci
make sure you dont have 2 of the keys close together if the chips in the black key handle get close to one another it can cause problems.....just an idea
Old Jun 27, 2003 | 06:06 PM
guerojo's Avatar
guerojo
I guess to late but it sounds like blown fuse. Wont kick or roll windows down, something jarred when he punched it. Or ground cable got loose with same jarring. Ground cable at block or someplace else. The same happened in my new truck. I think the filter was coincidence.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Workshop12
Mar 23, 2020 01:45 PM
StateNuke08
Oct 31, 2015 05:01 AM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
Beater350z
Sep 9, 2015 03:36 PM
