how to open trunk w/o remote!!!!
Old Jun 30, 2003 | 04:16 PM
alvareztony's Avatar
alvareztony
Default how to open trunk w/o remote!!!!
has anyone tried to open the trunk with the hatch release under the strut bar. I have the battery disconnected (doing some installs) so i can't use the remote or the trunk release above the rear license plate. i looked in the manual to see which way to pull the cord, but nothing seems to work. it says it will release the trunk even with the car off and battery disconnected incase of emergency, but mine doesn't seem to work. i've pulled hard on the string while a friend pulls up and down on the trunk, but nothing. need help please
has anyone else had this problem. what would you recommend. how did you get it to work.
thanks
tony
Old Jun 30, 2003 | 04:23 PM
Z4KR's Avatar
Z4KR
It doesn't take that much force to pull the hatch release. I did it once and had no problem. Didn't need anyone yanking on the trunk from the outside. Good luck.
Old Jun 30, 2003 | 04:27 PM
Z4KR's Avatar
Z4KR
Seems like there might be something wrong with yours.
Old Jun 30, 2003 | 04:35 PM
travelmadness's Avatar
travelmadness
my trunk release under my strut brace doesnt work either. (that, or i'm an idiot)
Old Jun 30, 2003 | 04:55 PM
jikman01's Avatar
jikman01
Ok, I just tried mine today for the first time. I pulled it until I felt as if it was going to slice my finger off then I stopped.
So then I let my 16-year old daughter try and she used both hands and got it open.
With that said.....I think you should just try a bit harder because I got shown up by a 16-year old!!
Old Jun 30, 2003 | 05:45 PM
MannishBoy's Avatar
MannishBoy
In playing with mine, I figured out not to put my finger in the square hole, because it will cut your finger off. Just grab back where the velcro is and pull.
Old Jun 30, 2003 | 06:07 PM
jikman01's Avatar
jikman01
I agree. Don't stick your finger in the square hole and pull or else your finger will get cut off
Old Jun 30, 2003 | 06:22 PM
noahbuddy's Avatar
noahbuddy
I think the angle you pull at also has alot to do with it. Pull straight down and it takes alot of force. Pull to the right of the car and it was easier. (or the other way around, I can't remember)
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
