MPG - Im Impressed.
Originally Posted by Silverstone-Z
35mph... You can get better gas mileage in 4th or 5th gear rather than 6th.
Originally Posted by Starchecker
So it usually averages around 28 on the highway.
I have dropped the speed down to 60 just to see and the trip computer didn't really seem to increase the MPG .
At normal highwy speeds, (75-80) i get aout 28. But at 55, i get about 31. (But I do very litle driving at 55!)
bill
The only accurate way for people to measure this is to fill up their tank, drive for any distance, and fill the tank back up. Take the miles driven, divided by the gallons used to fill it back up and you have your mpg.
do people just drive to a highway, reset their trip computer once on the highway and just watch it for a few minutes?
35mpg sounds so unreasonable.
I notice that the fuel guage tells you your empty, when you really aren't.. for example.. It said I was empty, but when I filled up, I was able to put 17.5 gallons into the car (which has a 20 gal tank).. next time around, I drove a little longer when it said I was empty and put in 18.5 gallons.. So just wondering why they programmed the computer to tell us we're on empty, when we still have 2 to 2.5 gallons of gas left..
oh, by the way, for the past 500 miles of city/hwy driving, I avg 20.6 mpg
Originally Posted by KManZ
Agreed... if you think about it, a cruising gear is made for highway cruising... ala 55mph. Anything below that, you should be in a lower gear, otherwise the engine is lugging, as someone said above.
Originally Posted by TreeFiddyZee
Lead foot!
(Oh. So am I by-the-way.
) I run about 27 on the highway.
Do the aero changes of the track change the drag coefficient? I usually get about 30 mph averaging 70 mph. The Z is the only car I've been in that I can not hear the wind doing 100 mph or so. So that tells me it has a pretty slippery profile. I'm too impatient on road trips to slow down to 55 mph to improve my milage but it feel that in 6th at 55 or 60, the Z really is not lugging that bad. There's not tons of power but its not shaking and still feels smooth and linear. I guess I need to know what exactly defined "lugging" because the VQ doens't seem to mind as long as I stay about 2k rpms.
What is this "lugging" in 6th gear? I'm always in 6th from about 40mph on up (city driving) - I don't notice any lugging...
Cruise control, btw - great for increasing mpg on average. Use mine every day.
I don't get it. Why would MPG have anything to do with what gear you're in. Shouldn't it be how heavy you are on the throttle, seeing as MPG takes place in the cylinders, not in the tranny? I understand that your engine revs as well, but amount of gas in is determined by amount of air in (see maf or whatever that thingy is called).
And if my logic is correct (watson), wouldn't that mean your best gas milage would come from an appropriate ratio of throttle to gear? such as chilling between 2500 - 3000 RPMs.
I'm just guessing, but I always thought that going >35 in 6th was stretching your gears a little much... not that I don't do it all the time because I like that exhaust note
If I remember correctly, the "empty" warning is supposed to kick in with around 50 miles to go on a tank. I may be wrong, but i think it's a governmental thing.
Originally Posted by kneedragger81
the owner's manual says that the 350z has a 20 Gal tank, the tank acually has 20.2 Gal. I haven't really seen the empty light on my z but i've seen my trip computer go to 8 miles to empty, yet when i filled up, only 15 gallons would fit in my tank. Theoretically, i still have 5 gallons remaining when i filled up. have you actually seen the empty light? and how many gallons did your tank take when you filled up? this is good info....
On a side note. You all might want to watch when you fill up your tanks. I think I went to a station today that was doctoring their gas. While I was filling up my tank, the pump kicked off at 7 gallons. It took me another 10 minuted to dribble in another 6.5 gallons. The gas was foaming like crazy. Needless to say, I was a little more than fired up.
.. I will hit up the Ozarks this weekend.. and springfield!! We should plan a meet in MO......
