Just went threw a huge puddle!!!
Well guys right now in florida the weather is terrible i ws trying to get home avoiding all road that i knew would flood. Just about made it home ..on my road and hit about an 11 inch puddle. Car made it through ok.... when i got out and contuined driving the car sounded as if something was scraping the floor. I got to my house looked under the car and nothing, bodykit was ok...everything looked fine. So now im a nervous wreck so i just ran out and started the car ....started right up.... anyone know why i had such a disturbing sound.......is my ok? helpppp
You might have broken the platic under cover for the engine bay. I did the same thing with my PPW. Just look way underneath the front nose of the car. If its drooping, then it broke from the radiator support like mine did. Good luck.
So is it still doing it?
Also, does it sound like something is rattling just in front of between the seats? And included in that question "do you have test pipes".
I went threw a big puddle when mine were warm and they warped a bit and bump the firewall.
You'll need to do more than just look. Put the front up on jack stands and check (pull) on the belly tray itself to see if it's broken in either the front or back. It may scape with water or mud and then spring back into shape. It comes off easily with 10 MM bolts and a few plastic clips holding it in.
i couldnt tell where exactly the sound was coming from...but i do have testpipes...its still raining now then im gonna jack it up and see if theres anythingi can see
Im thinking that you warped them. I warped mine so they rattle when cold but go back to normal when i heat them up a bit.
Try letting it cool down and starting it back up and driving around a bit. If you get some sound then thats probably what it is.
That's why you don't go threw puddles. If you through a rock or something into the puddle to check the depth, you could've saved yourself. You'll pull threw this don't worry.
I try to avoid going threw puddles... Especially deep ones...
But seriously
THROUGH
not
THREW
Originally Posted by kneedragger81
you should pop your hood, release hand brake, put it in 1st, then ghost ride your whip. You'd probably be able to better tell where the noise is coming from if your outside your car.
The man has a problem and asked the community for help and you give him this ****.
As for those who are actually intelligent, let the thread continue.
I know that you feel a need to post something when you dont have any idea about whats going on but next time you should probably keep your dumbass comments to yourself.
High school? I wonder if the OP made it threw high school? His parents probably through him out...
I like your sense of humor.
And who the **** are you?
