Question about Driving Manual Shift~i am So Confused!
Old Nov 9, 2008 | 06:08 PM
Firebase99's Avatar
Firebase99
Originally Posted by Flick Montana
Nothing useful to add. Just a good laugh.
Yeah, me either but that was funny as stink!
Old Nov 9, 2008 | 07:28 PM
Z-Lover's Avatar
Z-Lover
Originally Posted by AML225
Everything said about bucking is dead on. All manual cars do this to some degree. In the Z, with it's very close gear ratios remember that if the car is at all rolling or moving you can be in second. You can even use second to get the car rolling from a complete stop but there's really no point for that. When I'm in the parking lot and need to be slowing down and turning and maneuvering I keep the transmission in 2nd gear and alternate between pushing the clutch in and out to get the proper speed for whatever I'm doing. I only really use first for pulling away from a dead stop.
i guess i will try to use 2nd when i am driving around in a parking lot..
Old Nov 9, 2008 | 07:29 PM
Z-Lover's Avatar
Z-Lover
Originally Posted by TreeFiddyZee
You're getting what's referred to (by me anyway) as "bucking". If it starts doing that, push in the clutch. The way to avoid it is to let off of the gas slower. When you release quickly, it starts that torque whip. If it's bad enough, it's self-sustaining because it bucks, your foot hits the gas and it bucks harder.
Basically, just don't let off of the gas so fast, or conversely, don't hit the gas so hard when you're coasting with high revs.
edit: Oh yeah. And if you can't stop doing it, then roll your window down, hold your arm out the window and yell "Yeeeeeee-Haaaaa".
hahaha..thanks very much for your advice. i will try to let off the gas slowly next time
Old Nov 9, 2008 | 07:30 PM
Z-Lover's Avatar
Z-Lover
Originally Posted by zix07
as said before its called engine breaking and its perfectly normal. I have the same issue but i mean I've ridden motocross for years so there is alot worse engine breaking on the race bikes. But its nothing to get **** about. If it bothers you keep it in neutral or shift. If you still want to complain about it you can always go trade it in for an automatic....
i traded in my automatic a couple of weeks ago for this manual 350Z , now u wanna me to do it again?
Old Nov 9, 2008 | 09:33 PM
When you disengage the clutch the car slows down. Funny how that happens.
Old Nov 10, 2008 | 09:37 AM
m0nkie's Avatar
m0nkie
I don't have the Z anymore, but I did pick up my first manual car.. You'll get over this soon, I just messed around with it till I got some smoother riding.. For me, I either let go of gas slower, toss in N (don't do very often). If it's kinda moving but not, just let off the clutch a little and go very slow without hitting gas, if it moves just a bit faster, I go to 2nd...
Old Nov 11, 2008 | 07:06 AM
adamtaylorpcb's Avatar
adamtaylorpcb
easy fix
when starting out take it to 5k rpm and dump the clutch
see its just 1 big jolt now instead of a bunch of little ones
problem solved
Old Nov 11, 2008 | 08:42 AM
SilverstoneZ's Avatar
SilverstoneZ
compression braking
Old Nov 11, 2008 | 08:44 AM
Z-Lover's Avatar
Z-Lover
thanks man,.Z is my first manual car as well..and i did mess around with it a bit for the first couple of days of getting it from dealership..that's why i have a lot of questions regarding driving a manual.
Old Nov 11, 2008 | 08:45 AM
Z-Lover's Avatar
Z-Lover
Originally Posted by adamtaylorpcb
easy fix
problem solved
take rpm to 5k in 1st gear? dump the clutch? then what? shift up?
Old Nov 11, 2008 | 09:28 AM
Spork's Avatar
Spork
It's just in a really low gear. If you must let off in first, try releasing the clutch really slow. This should let the drivetrain match the speed of the engine and reduce the bucking.
Old Nov 11, 2008 | 09:56 AM
i8acobra's Avatar
i8acobra
It's called "driveline lash". There's some slack in the mechanical parts. When traveling slowly in gear, the car will sometimes bounce between the two extremes of the slack. The wheels cause the motor to turn, then the slack unwinds and the motor causes the wheels to turn, then the slack winds back up again. This is exacerbated in the Z by the dual-mass flywheel. When traveling at slow speeds, you need to slip the clutch a little to keep this from happening. Either that, or accelerate a little, then press the clutch in and coast, then let the clutch out and accelerate, then press the clutch in and coast, etc...
Old Nov 11, 2008 | 10:21 AM
SilverstoneZ
wtf
Old Nov 11, 2008 | 10:40 AM
JCat's Avatar
JCat
If you can't stop doing it, then roll your window down, hold your arm out the window and yell "Yeeeeeee-Haaaaa".
Best laugh I had today !!
Old Nov 11, 2008 | 12:56 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Nope. Just keep going 'til you heard a really loud boom. Than, go buy an auto and you won't have to worry about it again.
bcoffee20
Nov 19, 2015 06:39 PM
Ace2347
Sep 22, 2015 03:12 AM
