Scraped the Bottom of the Z!!!
Old Feb 3, 2009 | 07:05 AM
j1234's Avatar
j1234
Originally Posted by KManZ
You probably scraped the carbon fiber drive shaft, but since it is made of carbon fiber it withstood the impact and snapped back into place. Carbon fiber can take a shotgun blast from God himself.
more than likely the cats. the drive shaft is tucked way up inside the car, he would have to go over something that likely wouldnt clear his front bumper to hit that and be skinny enough to miss the exhaust.
Old Feb 3, 2009 | 09:40 AM
KManZ's Avatar
KManZ
Yeah, I know
Old Feb 3, 2009 | 09:43 AM
Entaille's Avatar
Entaille
sarcasm WOOOOOOOSH
Old Feb 7, 2009 | 05:25 PM
Nicks93090's Avatar
Nicks93090
yah same happ 2 me i went my friends house going up his drive way scrape... going back down in it reverse.. i hear a pop but my z is still fine.. no scratches thank god but cant see the bottom! haha
Old Feb 7, 2009 | 05:30 PM
Flick Montana's Avatar
Flick Montana
My wife and I found a great house online. Went to look at it and it was very cool and in a great neighborhood. She got out, all excited to look at it, turns around to see me banging my head on the steering wheel. It takes her a second to realize there is zero chance of me clearing the curb into the driveway.
The life of a Z owner is such a hard one.
Old Feb 8, 2009 | 08:22 PM
SchismX's Avatar
SchismX
You'll be fine. I have scraped many times. The first thing to usually scrape is the heat shielding around the y-pipe and cats.
Old Feb 8, 2009 | 08:41 PM
tanabe350z's Avatar
tanabe350z
he is right. dont worry too much, if it really bothers you that much take it to a shop pop it up on the lift and check it out
Old Feb 9, 2009 | 02:49 PM
token_z's Avatar
token_z
i jump a sideway on my Z (i was messing with my phone so i was a dumbass for not looking at the road ) ...every cool on my im sure ur ok......
Old Feb 9, 2009 | 03:04 PM
KT30's Avatar
KT30
Why are you up the driveway straight? Especially with a lowered car you should go at a steep angle otherwise you will scrape. (get one wheel over first and then the next)
There are a lot lower cars out there, and get driven everyday. Just learn to drive a lowered car and you will be fine (worst case, you PROBABLY scraped your exhaust or an underbrace.
Old Feb 9, 2009 | 03:18 PM
jmccarty's Avatar
jmccarty
Mine looks like a war zone underneath! We did find that my oil pan was slightly cracked after installing the oil cooler but this might have been done when removing from my old block but I can't be sure since it was done in the shop. Anyway, I replaced mine with an HKS heavy duty pan.
Old Feb 11, 2009 | 02:08 PM
350z Guy's Avatar
350z Guy
that sucks to see that happened to you, i last month i scraped my mudguards
i made a wide turn off of the drive way to avoid scraping my lip and ended up turning a bit too wide and driving off of the sidewalk...
happens to the best of us.
Old Feb 11, 2009 | 02:14 PM
Crom's Avatar
Crom
Just get a front sway and a front GT-spec bar...it will help protect the oil pan.
Old Feb 11, 2009 | 08:11 PM
jmccarty's Avatar
jmccarty
Good suggestion.
Old Nov 6, 2009 | 01:19 AM
brandon3434's Avatar
brandon3434
i scrape all the time...dont worry about it...however, my transmission just started leaking and I have no idea why...uhhhhhh OHZ NOZ!!!
Old Nov 6, 2009 | 01:25 AM
_STEVEO_01's Avatar
_STEVEO_01
You should be fine, as long as you don't scrape the oem dual flux capacitors that come standard located near your cats. Those bishes are expensive to replace...
Old Nov 6, 2009 | 03:01 AM
winchman's Avatar
winchman
The Nissan factory Service Data and Specifications lists a minimum oil pressure
(shown below).
Approximate discharge pressure (psi)
Idle speed More than 14
2,000 RPM More than 43
6,000 RPM More than 57
Old Nov 6, 2009 | 03:18 AM
DavesZ#3's Avatar
DavesZ#3
Why are you guys replying to a 9 month old thread????
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
Tochigi_236
Sep 27, 2015 03:40 PM
350zrn35
Photoshop
Sep 14, 2015 06:53 PM
