New MT Driver 1st Gear Shifting
Old May 13, 2009 | 09:16 AM
rockinbboy's Avatar
rockinbboy
Originally Posted by Xlr82x
I have been driving a stick for a while and never rev'd it up that high to get going. If you learn to move your feet sequential to eachother, then you wont need to start with a high rev. Focus on release the clutch at the same rate that you are applying the gas..
+1
Why do you need to rev to freaking 2500? wow, you launching the damn vehicle or what? That is one way to wear out your clutch faster.
You shouldn't have to give more than 500 rpm to the idle rpm to get moving.
I can get the car moving with ease without even applying throttle (unless it is an incline).
I try to keep the RPM under 1000 from a stop and go.
Old May 13, 2009 | 09:30 AM
Get_Zwole's Avatar
Get_Zwole
Originally Posted by rockinbboy
+1
Im sitting here thinking the same thing wondering if im on the same page as everyone else. from a stop or 1 to 2 shift? rpms shouldnt have to come above 1k from a stop, unless on an incline. 2500 is insane i launch at the drag strip at 3k.
Old May 13, 2009 | 09:57 AM
blktrack350's Avatar
blktrack350
x3 i was wondering what i take off at today and i dont even pass 1k from a stop. what are these people doing going up to 2500rpm to take off.
Old May 13, 2009 | 10:36 AM
tanabe350z's Avatar
tanabe350z
people who think they know how to drive post these things lol, honestly ive gotten my car rolling without gas lol. most people do rev so high because they cant find the sweet spot in the clutch to effectively use it.
Old May 13, 2009 | 10:48 AM
fabcas311's Avatar
fabcas311
Originally Posted by neox
Rev it to about 2500rpm, let out on the clutch til you feel it start to catch, then give it slightly more gas as you release the clutch the rest of the way.
Old May 13, 2009 | 11:25 AM
350z Guy's Avatar
350z Guy
wow... 2500 rpm? thats over doing it for me, the highest i will accidentally rev to would be 2000 rpm
i always rev up between 1000 and 1500 rpm
how is it even possible to rev that high to just get off from a stop...
Old May 13, 2009 | 12:21 PM
fabcas311's Avatar
fabcas311
or u can just use the clutch to get off from a stop..that is a good way to practice to feel the engagement point of ur clutch
Old May 13, 2009 | 12:26 PM
NISMO_558's Avatar
NISMO_558
Really, ANOTHER "how to drive a manual transmission" thread. It seems like theres atleast one a week.
Old May 13, 2009 | 03:38 PM
juju's Avatar
juju
I don't know what I rev to b/c I don't watch the tach (rely on feeling), but I know I'm definitely not reaching 2500.
Old May 13, 2009 | 05:11 PM
StillenGle's Avatar
StillenGle
Put it in reverse its alot easier to feel where the clutch is with out stalling.
Old May 13, 2009 | 05:46 PM
Get_Zwole's Avatar
Get_Zwole
no wonder people on this forum go through so many clutches.
Old May 14, 2009 | 01:59 AM
Barnabas's Avatar
Barnabas
National Z Club President
I only use the gas when startign off if I am on a hill or on the drag strip there is no reson to ever rev to 2500 when DDing
Old May 14, 2009 | 07:30 AM
2008G41's Avatar
2008G41
Good info guys thanks.
How is this possible?
Old May 14, 2009 | 10:41 AM
blktrack350
you just let the clutch out slower that you would if you did give it gas
Old May 14, 2009 | 10:46 AM
gismo's Avatar
gismo
keep practicing. i was like that too.
Old May 15, 2009 | 07:44 AM
StillenGle's Avatar
StillenGle
If the car has alot of Torque, its easy, just slowly let up the clutch, you"ll start to roll then lightly hit the gas that way the car won't stutter.
Old May 15, 2009 | 10:23 AM
Darkpath's Avatar
Darkpath
Originally Posted by ZBigDog
oh and as weird as this sounds, the more you "think" about the luanch and timing, the worse you do..it's just gotte feel natural and not 'under the gun' so to speak...as good as I am at my starts..I'd fail miserably at my first few 1/4 mile launches when under pressure
Zrythmn - its got a good beat... you can dance to it... I give it a 98...
(^ reference American Band Stand - circa 1968) LOL
Old May 15, 2009 | 04:47 PM
  #38
bailey bill's Avatar
bailey bill
You will never learn to drive a manual tranny reading a book , or sitting at the keyboard.
The only place you will learn is in the driver's seat. Just keep driving, and it will al become second nature.
bill
Old May 16, 2009 | 12:43 PM
  #39
phos's Avatar
phos
Even though the general principle is often mentioned, first gear start with manual is affected by several factors. There's cold/ hot engine & transmission, a/c on/off, passenger weight y/n. a - d below then will be a bit different with these 3 conditions.
Then, there is the acceleration rate;
a) Oft-mentioned no-gas roll-up,
b) bumper2bumper traffic 1rst gear roll & coasts,
c) the regular green-light brisk pace,
d) the 0-60 in 5.3.
There are two points that induce engine/wheel power mis-match: not giving enough gas after first clutch contact, and not continuing to add gas after that point. The first tends toward stall, the second produces smooth but sudden deceleration due initial momentum being braked by reduced rpm as car mass has just been accelerating.
a) does not deal with 2nd point, but does show you where initial clutch grab begins. also, this is not sufficiently fast at green light to ever use unless you're the only car on the road.
b) requires a bit more and stop-go traffic is good practice time to learn to avoid point two as you usually need to get past initial movement up to 10 or 15 mph which is ez soft entry to 2nd.
c) needs the smooth and coordinated gas & clutch synchronization; it's not so much about inital revving as timing of gas before clutch grab then more gas and total clutch release in one non-faltering leg pedaling. the Z is heavy, rpms = power; certainly more than 500 before '2nd point', though over 1000 is going to get unnecessary clutch wear, IMO, but you do need to rapidly feed gas to move the beast and continue w/out trepidation. best mood is to just be annoyed with stoplight concept and the rest can flow.
d) i suppose this is done with 2 gears as 2nd redlines @ 66 w/ HR, but maybe someone else can comment on it, i still take a little less than that just to get out of 1rst after 2k miles.
Old May 16, 2009 | 03:48 PM
  #40
No slip light
It's when the clutch is almost all the way out I feel a loss of acceleration
Sorry still don't get it. The car will not accelerate unless the clutch is OUT.
