Ways to get under the car safely???
Old Jul 10, 2009 | 08:13 AM
Z redZ's Avatar
Z redZ
Default Ways to get under the car safely???
Hi,
I just recieved my test pipes and i want to install them myself to save money. My question is regarding how I would be able to gain access to the underside of my Z. Would the jack that comes with the car lift the car enough and safely to install the pipes or is there another way.
This is probably a stupid question but forgive me.
Old Jul 10, 2009 | 08:24 AM
JEKL's Avatar
JEKL
Originally Posted by Z redZ
Hi,
Don't get under the car with the factory jack!!
Go and buy a low profile jack and a pair or two of quality jack stands. I prefer ramps myself but that's just me. You will end up spending more on those pieces than you would paying someone to put on the TPs for you. But you need those pieces for a bunch of other routine tasks as well so its worth it.
You really just need to lift one side at a time to do it, not the whole front.
Old Jul 10, 2009 | 08:26 AM
teh215's Avatar
teh215
+1 on avoiding the OEM jack. A good set of jackstands are the best solution.
Old Jul 10, 2009 | 08:30 AM
DavesZ#3's Avatar
DavesZ#3
If not jack stands, get some ramps.
Old Jul 10, 2009 | 08:35 AM
*ICE*'s Avatar
*ICE*
haha test pipes?!? good luck with changing them out if you only have jack stands!
Listen to me now, better take it to the shop and pay around $50-$90 to get them change. Trust me, you will thank me later. Those pipes are a bitch to SWAP!!!!
Old Jul 10, 2009 | 08:37 AM
teh215's Avatar
teh215
I didn't have any problems.
Old Jul 10, 2009 | 08:46 AM
35oZephyR's Avatar
35oZephyR
At the very least, throw some stock wheels or something underneath the car.
With Cali earthquakes out here, I don't even trust jackstands alone.
Old Jul 10, 2009 | 09:47 AM
NismoTreeFittyZ's Avatar
NismoTreeFittyZ
Since you were even considering crawling under a car with just the factory jack holding it up....you should have someone else install them. Paying $75 is better than paying the hospital or funeral home bill.
Old Jul 10, 2009 | 09:57 AM
Absolutely not.
4 jack stands is safe. Still you should not be under a car banging with a big hammer or pushing and pulling.
Old Jul 10, 2009 | 10:08 AM
JCat's Avatar
JCat
Here you go !!
Old Jul 10, 2009 | 10:18 AM
JasonZ-YA's Avatar
JasonZ-YA
Okay op,
honestly sounds like you should pay a shop, but if you insist on doing it yourself, then take the advice given above...
Now for the picture above on post #11:
I cant stand that picture .........the really bad chop work on it is one thing, especially toward the rear of the car......
But the jack points up front are HORRIBLE!!! for one look at the right side top point they are using to jack up at(when looking at pic) --- which is in turn the passenger side front.
YOU DO NOT JACK "ON" or near fuel lines -----uuumm Kay?!
Those are not the correct front jack points. consult your owners manual or download the FSM (factory service manual)
-J
Old Jul 10, 2009 | 10:27 AM
beezee's Avatar
beezee
Spend a little money, stay safe.
Old Jul 10, 2009 | 10:28 AM
Dr. Venture's Avatar
Dr. Venture
^^^wow i said the same thing! Who in the hell put this car on the lift, a Monkey?
Just get it done makes life much more easier instead of being a cheapo.
Old Jul 10, 2009 | 10:31 AM
diablox1's Avatar
diablox1
Old Jul 10, 2009 | 10:56 AM
terrasmak's Avatar
Originally Posted by dave079
Anyone asking how to get under the car safely should not be changing their test pipes themselves.
Not to mention probably doesn't have the tools needed to do test pipes.
Old Jul 10, 2009 | 11:35 AM
Mike@Blackline's Avatar
Mike@Blackline
to replace your cats with test pipes, clearly the best way to get under the car would be with cat jack stands:
Old Jul 10, 2009 | 12:48 PM
Dr. Venture
1. Dig a big ditch
2. Get in the ditch
3. Have someone drive your Z over the ditch
4. Perform the works
5. hmm...if you made it this far, that is on you.
Old Jul 10, 2009 | 12:57 PM
Spork's Avatar
Spork
Jack up one side.
Put 2 jackstands in place.
Jack up other side.
Put 2 more jackstands in place.
Old Jul 10, 2009 | 01:29 PM
Legacy406's Avatar
Legacy406
Trust me its a pain to do it without a lift. \Tried doing mine on ramps and theres not much room to work with and getting up by the headers will be a pita. If you know someone who works at a shop get it on the lift you wont regret it.
