AM I a 2004.5 or 2004?
Old Oct 14, 2009 | 08:19 PM
TwiZted's Avatar
TwiZted
Default AM I a 2004.5 or 2004?
Here is the criteria for the VIN to determine if it is indeed a 2004.5:
Production at Oppama Plant (T) (to be discontinued at the end of April 2004)
For Coupe models
JN1AZ34D*4T160001
JN1AZ34E*4T060001
D*4T153673
Production Date: 10/2003
I don't know how to read the chart. I have a knee pad on the pass side.
Thx!
Old Oct 15, 2009 | 03:13 AM
DavesZ#3's Avatar
DavesZ#3
Here are the instructions...
2004 Nissan 350Z Coupe/Roadster (Coupe VINs up to D*4T160000,E*4T060000) (Roadster VINs from D*4T102001 to D*4T110000 & from A*4T002001 to A*4T010000)
2004.5 Nissan 350Z Coupe/Roadster (Coupe VINs from D*4T160001, E*4T060001) ( Roadster VINs from D*4T110001, A*4T010001)
Your vin number is 153673 which is less than (i.e. up to) 160000, right? You have a 2004.
Old Oct 15, 2009 | 06:52 AM
tiffuhhkneex0's Avatar
tiffuhhkneex0
its a 2004.
Old Oct 15, 2009 | 07:22 AM
illjim69's Avatar
illjim69
Does it matter? Other than a slight change in the suspension, is there anything different between the two?
Old Oct 15, 2009 | 09:01 AM
DavesZ#3's Avatar
DavesZ#3
Yes, it does matter. A 2004 is essentially the same as the 2003. The 2004.5 models are where the changes came into play. I know for a fact that the wiring harness is different because I was trying to use a 2004 manual to track down something on my 2004.5 and it didn't work.
Old Oct 15, 2009 | 05:27 PM
TwiZted's Avatar
TwiZted
Thank You
Old Oct 15, 2009 | 09:52 PM
illjim69's Avatar
illjim69
Fair enough. Honestly, I thought they were the same thing minus the suspension/tire feathering thing.
Learn something every day.
Old Oct 16, 2009 | 02:47 PM
ak350's Avatar
ak350
I thought knee pads meant you had an 04.5 ?
Old Oct 16, 2009 | 03:02 PM
DavesZ#3's Avatar
DavesZ#3
Only if your VIN number falling into the range I listed above.
Old Oct 17, 2009 | 11:54 AM
j.arnaldo's Avatar
j.arnaldo
Thanks, guys! You indirectly helped me determine I have an '04.5---f-l-a-w-l-e-s-s, so far!...NO feathering, NO starting problems, NO overheating issues, seamless AT!!! The only problem I've had with her is the driver's side power window motor; I had to replace it, early this year. Otherwise, a SWEET ride!
Old Oct 17, 2009 | 02:16 PM
scrillasherv's Avatar
scrillasherv
What does it mean when the car has a "corrected title" on the record? The VIN number (I won't put the whole thing) but it goes JN*AZ**D74M******. All the *'d are numbers.
Old Oct 17, 2009 | 06:33 PM
DavesZ#3's Avatar
DavesZ#3
CLICK HERE
Old Oct 17, 2009 | 11:00 PM
scrillasherv
I have no idea how you did that but that was amazing, no I'm not being sarcastic. And how can I tell if it's a 04 or 04.5? The VIN # doesn't follow the VIN's you listed, it doesn't even have a "T" in it.
Old Oct 18, 2009 | 05:28 AM
DavesZ#3's Avatar
DavesZ#3
The full explanation goes like this...
If the letter before the 6 digit serial number is "M" instead of "T", it's a 2004.5 because it was produced at the Oppama plant.
Old Oct 18, 2009 | 08:21 AM
scrillasherv
Ah I see. Really appreciate it
Old Dec 1, 2009 | 09:12 PM
medic165's Avatar
medic165
thanks for the info..i got the 04.5
Old Dec 2, 2009 | 01:08 AM
TittieZ's Avatar
TittieZ
Thanks for saying what we're all thinking...
Old Dec 2, 2009 | 05:02 AM
silvertouringz's Avatar
silvertouringz
hey really nice thread!! mine is a 2004 and it goes like this : D*T160324
thats a 2004.5 right? in which plant it has been produced? and whats the difference b/w the oppama plant and the others? thanks
liqalu04
Jan 2, 2022 12:58 PM
_bit
Oct 2, 2015 07:49 AM
