Size of grill
Old Aug 31, 2002 | 03:57 PM
SunsetZ's Avatar
SunsetZ
I just held a licence plate up to the opening. It is a perfect fit. Because the black of the grill is further forward in the middle vs. the top and bottom. So the rounded edges of the top and bottom, above and below the grill allow for the plate to fit perfectly.
Old Aug 31, 2002 | 09:54 PM
AudioPat's Avatar
AudioPat
Up Front Enterprises
Cool
Do you think it will fit with a frame around it or will it have to be mounted without a frame
Old Sep 1, 2002 | 02:33 AM
roberto350z's Avatar
roberto350z
youd have to chop up the frame too
Old Sep 1, 2002 | 03:49 PM
SunsetZ's Avatar
SunsetZ
You could probably do a frame also, it just might not be touching the black plastic of the grille (it would be sticking out just a little) just touching at the top and bottom of the grille surround.
Old Sep 1, 2002 | 08:50 PM
AudioPat's Avatar
AudioPat
Cool
Yes..that would probably work..looks like the grill opening is flared outward so making a bracket that extends outward an inch or two might just work..would probably also be better for air circulation...I'm working on it but wish I had my Z...it would make it a lot easier...can anyone give me the vertical measurement of the grill opening at it's widest point in the center, and also the distance from the tow hook recepticle to the front of the grill opening?(pardon my spelling)
Old Sep 1, 2002 | 11:35 PM
roberto350z
apparently there is not circulation involved with the grill
Old Sep 2, 2002 | 05:51 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Hey Pat, I'm proud of you! Doing a little Photochopping I see! Must be hard working on that front grill with Spanky "monkeying" around you though huh?
Old Sep 2, 2002 | 08:35 AM
Subw00er's Avatar
Subw00er
Driven and others, I'll keep you posted...
SunsetZ, thanks for checking..!
Apexi350z, check your personal messages!
Old Sep 2, 2002 | 09:27 AM
AudioPat's Avatar
AudioPat
Cool
Makes it easy to find a Monkey Wrench though
Old Sep 2, 2002 | 12:00 PM
TCL's Avatar
TCL
How much air flow to the radiator do you all think would be blocked by mounting the plate in the grill? If the only flow to the radiator is a small area in the center of the grill, then mounting the plate there might not be desirable. Could anyone who has the car take a quick look? Thanks.
Old Sep 2, 2002 | 03:14 PM
roberto350z
there was a thread about this before..I will summarize what they said:
It appears that circulation is not involved with the grill.,
Old Sep 11, 2002 | 08:16 PM
Seattle_350Z's Avatar
Seattle_350Z
Subw00er,
I saw those exact same grill on my co-worker S2000. It looks very sharp! What company makes it???? You know where I can buy that material???
Old Sep 11, 2002 | 08:41 PM
Subw00er's Avatar
Subw00er
Contact http://www.grill-tech.com/ Ask for, or email Chris.
Old Sep 11, 2002 | 10:52 PM
Wiley's Avatar
Wiley
Originally posted by Apexi350z
Perfect for intercooler
YES very perfect!!!!!!
sales@czp
Sep 23, 2019 03:30 PM
