I Need Help Fast!!!!
hey guys i need some serious help fast i was trying to install my ground kit and one of the factory bolts broke off( its the one for the ground) and im have no idea what to do now, im not that mechanically inclined so i am stuck, if you can help pm me and i will call you if thats ok..........thanks john
Go to Autozone and by a tap set.......about 12 - 15 dollars.....you'll need to drill a hole in the center of the remaining bolt, and then use the tapping tool to remove it..........not to difficult. Autozone should be able to guide you through it.
Good luck
Good luck
thanks i think i solved the problem...i just drilled a hole in the hood sensor mount and cleaned the paint off of the area with a wire brush and then installed the ground and new grounding kit wire onto the mounting bracket...i think this will work well if anyone has any input feel free......
seagrasser
Oct 11, 2015 03:27 PM
