Is the 350z 6 speed hard to drive
Old Dec 30, 2009 | 09:17 AM
  #41
chinabean's Avatar
chinabean
it'll be a lot more powerful thats for damn sure
Old Dec 30, 2009 | 02:25 PM
  #42
350z Guy's Avatar
350z Guy
personally its one of the hardest stick shift cars to drive mainly because the engagement point of the clutch is alot higher than other MT cars
but once you get the hang of its high engagement point you should be finee
i am so use to the high engagement point that i stall when driving my friends car since his engagement point is so much lower
Old Dec 30, 2009 | 09:56 PM
  #43
tiffuhhkneex0's Avatar
tiffuhhkneex0
it took me like 2 days to get completely used to my car, its also my first manual car, its easy, the clutch doesn't catch till the end, like when its almost all the way up. that's on a bone stock Z anyway.
Old Dec 31, 2009 | 06:08 AM
  #44
Dr. Venture's Avatar
Dr. Venture
watch out for red lights on hills!!!
Old Jan 5, 2010 | 02:40 PM
  #45
sirbrian's Avatar
sirbrian
My 350z was my first car to learn stick in. Yes I'm crazy. But yea the 350z is easy to learn with. They made it so that middle aged men in their mid life crisis won't stall as much. I'm only joking. But yea don't be scared of the Z. Tame the beast! Best of Luck.
Old Jan 5, 2010 | 03:42 PM
  #46
m3ds's Avatar
m3ds
I've only had MT cars... and it's easy to drive, but hard for me to drive smooth. Maybe I just suck at driving MT (I doubt, cuz I've had 6 others lol) but I rarely get a smooth shift unless I'm WOT lol
Old Jan 8, 2010 | 11:12 AM
  #47
whitelightnin's Avatar
whitelightnin
wreck it yet?
Old Jan 8, 2010 | 11:15 AM
  #48
Dr. Venture
smell anything burning?
Old Jan 8, 2010 | 12:15 PM
  #49
Moncada90's Avatar
Moncada90
yeahh the 6mt on the z is pretty smooth!!! ooohhh ****!!! i burn my clutch last month never mind.... haha jk
Old Jan 9, 2010 | 06:27 PM
  #50
phos's Avatar
phos
Default jumping short gears
Originally Posted by ckthepilot
I used to own a Mustang GT and the 350z gear shift points are so long. I'm still not used to it yet after 2 years of owning mine
shift points long? don't you mean narrow? iow, every higher gear is only about 500rpm over lower, except for OD/6.
key is to jump 1 3 5, 2 4 5/6 depending.
a 4s will be longer, 6s {5.1} is narrow so that one can always downshift into 2k launch base entry area of max torque range 2k-4k.
for me, the difficult part is to get used to the linear wire gas mode; at light in fast traffic need to depress further to get into 1K and up to get going quickly than in regular exponential pedal where a slight tap boosts rpm's up past 1K. a smooth clutch release with pedal mash works just right after contact.
for murderous (relatively) acceleration i'll do
1-->3k, 2-->5k, 3-->6k, then 5 to jail.
moderate trot will allow flip into 2, then 4 and finally 6 at 50.
sequencing 1,2,3,4,5,6 is just for exercise in traffic.
Old Jan 9, 2010 | 06:37 PM
  #51
phos's Avatar
phos
Default high engagement
site has write-up on lowering clutch pedal if needed.
Old Jan 10, 2010 | 09:41 AM
  #52
SLeRoux92's Avatar
SLeRoux92
i just read A LOT and watched tutorials on youtube before learning to drive stick and when one of my friends finally bought one he taught me. i only stalled once, strangely enough on my third start. unfortunately i dont own a z yet, but i'll definitely get the 6mt when the time comes. worst case scenario i burn out the clutch (doubt it though) and buy a performance clutch..
Old Jan 13, 2010 | 04:15 PM
  #53
Caledan's Avatar
Caledan
Just a little bit of patience, practice and dedication and you will do fine~ My Z was also my 1st manual and it took me about 2-3 days to get the hang of it~ Clutch point like many have said is higher (near the end almost) but it's not hard to drive. Have fun
Old Jan 14, 2010 | 02:50 PM
  #54
fordslowcus's Avatar
fordslowcus
my 95 subaru legacy shifting is looser than a moist 60 year old ***** on a hot summer day. I let everyone learn on that thing lol. Wont let you go drive one single block in the Z though.
Old Jan 14, 2010 | 09:38 PM
  #55
sARRsilvguy's Avatar
sARRsilvguy
The first time I tried reversing in a Z I stalled it. I totally forgot it was a 6 speed!
Edit: 1st post
Old Jan 15, 2010 | 05:00 AM
  #56
Dr. Venture
Just rev is to about 5000 and let go of the clutch.
Old Jan 15, 2010 | 11:50 AM
  #57
BlueSQ's Avatar
BlueSQ
Originally Posted by winchman
Rent a manual shift car for a day to get some practice, even if you have to go to one of those places that rents junkers. Don't take a chance on messing up your own car.
x2
Z clutch isn't cheap.
People usually learn on trucks and compact cars. Performance cars like these act different - they're not forgiving. There's one sweet spot, and you gotta learn it. Miss it and be doomed to lurch around town.
Old Jan 15, 2010 | 11:55 AM
  #58
BlueSQ's Avatar
BlueSQ
Make sure you literally slip your foot off the clutch too so you slam that pressure plate, then womp the throttle.
TCS needs to be off too or the car won't run
Jerking the wheel violently in either direction usually smooths out the start.
Old Jan 15, 2010 | 10:33 PM
  #59
ss7falcon's Avatar
ss7falcon
I find it harder than my last car to shift smoothly in normal/slow city type driving (2nd gear in particular). But accelerating quickly and shifting at high rpms its as smooth as butter
But you should be fine once you learn on it.
Old Jan 16, 2010 | 03:55 PM
  #60
blkfairlady05's Avatar
blkfairlady05
make sure you start in 3rd gear and dump the clutch at about 5500rpm.......this is the best way to learn everyone does it..... oh and make sure your e-brake is engaged
