A Canuck Z
Old Aug 30, 2002 | 10:15 PM
acid burn's Avatar
acid burn
Thumbs up A Canuck Z
Picked up my Silverstone Track Z in Saskatoon on Wednesday. It's been a long wait, since I gave them my down payment in November! The guys at Oakwood Nissan were great to deal with.
Impressions:
Torque-o-rama! Coming from a VTEC Honda Prelude, this is awesome. The engine revs quickly and does not "hang" at higher revs when you let off the gas. This car will unseat the Prelude as the "best handling car under $30,000". Suspension is very well controlled, but not rough. Turned off the VDC and peeled out while still staying under my 4K break in rev limit!
Shifter is shorter throw than the Prelude, the same as an S2000, but a little harder to engage. Clutch is on par with S2000, a little easier than the Prelude and a lot more precise.
The auto climate control works really well. Pretty much set the temperature and let it do it's thing. Only had to override it a few times.
Seat was very comfortable, I didn't have a sore back after the 7 hour trip home.
The car is smooth as glass up to 160 km/h. I didn't try higher. Wind noise is the same at 100 and 160.
The tires didn't seem to have the dry grip that my S-02 Pole Positions had on the Prelude. Maybe they need to be worn in a bit more?
The fit and finish is great. Material quality is what I expected. However I think the panel gap around the hood is a bit large. It closes easily though, as do the doors, with a light touch.
The car crowd really knows this car. People were asking me at stop lights and coming into the dealer to see it. On my way to Calgary (changing speed/gear every song on the CD :-)) it got just as much attention.
Enough for now. I still have 500 km more break in mileage to put in this weekend!
Old Aug 30, 2002 | 10:18 PM
roberto350z's Avatar
roberto350z
well. the stock tires are are no pole position, thats for sure. Alot people have bashed the OEM's....but anyway, just thought Id say SWEET CAR DUDE OMG I LOVE SILVERSTONE IM GOIN NUTS
the end
Old Aug 30, 2002 | 10:23 PM
acid burn's Avatar
acid burn
pic
Old Aug 30, 2002 | 10:25 PM
acid burn's Avatar
acid burn
pic 2
Old Aug 31, 2002 | 12:00 AM
SilverStreak's Avatar
SilverStreak
beautiful Silver
The Prelude has been unseated in that category for a couple years now. Oh, you should post up the head to head pic of your friend's S2K and your Z. They would love that on here
Old Aug 31, 2002 | 08:49 PM
mike952's Avatar
mike952
Default Re: A Canuck Z
Impressions:
I have asked this a few times around have gotten varying answers. How does the Z feel suspension wise compared to the prelude (unbiast please). I know the track rims with the higher PSI feel a little more rough. I have the 17" rims on the enthusiast though. I presume you had similar profile rims on the prelude; otherwise a comparison wouldn't be too fair.
Thanks.
Mike
Old Aug 31, 2002 | 09:12 PM
acid burn's Avatar
acid burn
On the Prelude I had SSR 17 inch rims with 215/40R17 Bridgestone Potenza S-02 Pole Position tires.
The ride quality is about the same, maybe a touch better. This could be because to get a good balance on the Prelude with these tires I had to run 38/36 PSI front/rear.
The suspension is much firmer, the body roll is much less. On the Prelude, the grippy tires seemed too much for the suspension. Sometimes the suspension would load up and then bounce back, maybe too much grip caused it to hit the bump stops on hard corners? But the balance was beautiful, to the point where I could do a 4 wheel drift on the highway on ramps.
I'm still getting used to the Z. I'll find out what tire pressures are best for the stock tires. I am thinking of getting S-02s for replacements.
I am not sure what the stock tires pressures are between 17 and 18 inch stockers, but I think what you mean is that the lower profile (45) of the 18s will ride rougher that the profile (55) of the 17s.
Old Sep 1, 2002 | 02:41 AM
roberto350z
what do you think that the tire shop would do if you changed the tires right away? They should pay for your old tires cuz theyre gonna sell them anyway!
Old Sep 1, 2002 | 07:53 AM
Subw00er's Avatar
Subw00er
Hey Acid Burn, what did you tihnk of the SSR 17 inch rims? I was thinking about getting them
Old Sep 1, 2002 | 12:28 PM
acid burn's Avatar
acid burn
The SSRs were great rims. Easy to keep clean and high quality. However, the Honda dealer bent a rim once on an inspection drive. I guess they didn't avoid pot holes and drive slow over speed bumps like I did. BTW, I expect this to be less of a problem with the Z because there is less weight over the front wheels and the 45s are taller than the 40s I was running.
As to why I got it in Saskatoon? The Calgary dealer "took my name and number" but never treated me seriously and never called me back to this day. ******. Saskatoon is my home town so a few visits were cool too.
Old Sep 1, 2002 | 03:16 PM
Peregrine's Avatar
Peregrine
Congrats on your new Z! I'm currently driving a 2001 Prelude, but considering the Z, so I was very interested to read your impressions.
One question: Did the Z feel like a heavier car than the Prelude (3200 vs 3000 lbs) or about the same? In particular, I'm thinking about the agility and tossability of the car during hard cornering, quick lane changes, etc. Of all the Z's stats, the weight was the only one that had me concerned...
Also, I know you're still probably taking it easy during the break-in period, but how does the acceleration of the Z at low revs compare the acceleration of the Prelude at WOT and high revs?
Thanks...
Old Sep 1, 2002 | 04:59 PM
acid burn's Avatar
acid burn
The Z feels lighter than the Prelude. Acceleration keeping the revs below 4K rpm is greater than the Prelude wound out to 7.5K rpm.
I haven't tried much corner tossing yet, but on one corner I did and the VDC invoked and braked the outside front wheel. The wheel made a short squeal (which startled a passing motorcylclist) but did not upset the car. I tried the same corner later with VDC off and there was no braking and no squeal. I will be driving with the VDC off now most of the time.
I can't wait until break in is over and I will rev it out to see what it can do. I hope the Nissan V6 endures the high revs as well as the Honda I4 does. I revved that one out regularly and it ran great. Also, fuel cut out did not engage until 400 hundred revs past the indicated red line. I have heard it is a common trait for Honda tachometers to read a little high. Anyone know if this is true for Nissan tachometers?
Old Sep 1, 2002 | 05:21 PM
acid burn's Avatar
acid burn
Silverstone pics. Will have better pics later when I can find a suitable photo shoot location.
Old Sep 1, 2002 | 05:23 PM
acid burn's Avatar
acid burn
Look at that metallic!
Old Sep 1, 2002 | 05:25 PM
acid burn's Avatar
acid burn
Sorry I took it before I polished the tail pipes...
Old Sep 1, 2002 | 06:07 PM
baven's Avatar
baven
I dont think you will bend one of these rims because they are forged as well as having 1/4-3/8 more rubber sidewall.
You should be safe so long as you dont hit any trenches
Old Sep 2, 2002 | 10:28 AM
Peregrine's Avatar
Peregrine
Nice pics!
On the Prelude, Honda intentionally set the fuel cutoff a few hundred RPMs above the redline, so it's not (entirely) the result of tachometer inaccuracy. It also depends on engine temperature. When the engine is cold, the fuel cutoff will trigger below redline...
I'd be curious where the cutoff point is on the Z. Anyone hit the cutoff on their new Z (intentionally or not)?
Makriluc
May 10, 2015 05:39 AM
ReStylin
Nov 20, 2013 09:44 PM
