Flat-towing a 350z? Has anyone done it?
Does anyone know if there is a readily available tow-bar for flat-towing a 350z? Or, even a more generic solution that works well? Has anyone actually done this?
The giant threaded tow-hook hole in the front of my '05 looks promising, but I can't seem to find anything that makes use of it, or any other Z attachment points for that matter. I've flat-towed other track cars by just installing generic tow bar brackets and such, but the Z is less accommodating of that, and I'm hoping to find a more elegant solution... I don't really want to modify it much for this, and would like to avoid having to remove the front bumper every time. Quick and simple hitching and unhitching is what I'm after.
Thanks.
Thanks.
yeah actually buying a trailer is a much better choice, those tow hooks on our cars are more for emergency purposes, like hauling your car up onto a flat-bed via crank. but up to ho wmuch money you wanna hopefully save, versus how much you might end up paying for something else happening.
^ You cannot be serious. Flat-towing it from the rear is a sure-fire way to wreck it.
If the front wheels are free to move, the front end will swing out to one side with the rear end going the other way. If they're not free to move, the rear tires will scrub when you turn.
Did you mean to tow it with the rear wheels on a dolly?
I don't have space to store a tow dolly or trailer, and have been flat-towing other cars for several years and many thousands of miles, blah blah blah... I'm really just asking if anyone has already worked out flat-towing a Z, so that I might learn something specific to Z's, and avoid having to reinvent the wheel here. The Nissan manual specifically says you can flat-tow the Z, but I don't see any recommended attachment points or hardware.
Exactly. It's bad enough when you flat-tow a car from the front and the steering wheel is locked... after scrubbing around the first turn, you quickly realize that you fail and need to go unlock the wheel. Towing the car from the rear would have that problem, plus issues from the front wheels not being completely straight (even if they're locked, and worse if unlocked).
With an aluminum bumper on the car, i figure it would actually take some custom work to make it happen.
Don't mind most of the people on here, most of nintendo nerds or they worship the Z like its a $200k car.
U-Haul here charges around $45/day for a dolly, or $55 for a full trailer... With the amount of money I'd spend renting something for just one track weekend, I could just buy a whole tow bar setup and use it all I want, whenever I want. The money savings isn't that critical of an issue, but the convenience and independence of having my own towing equipment are huge selling points for me.
To each his own, though.
I just strongly prefer to have my own support vehicle (and some cargo capacity) with me at the track, and an easy and comfortable tow home if I break something. That works great when I race wheel-to-wheel, and I plan to eventually do the same with the Z.
"As long as the drive wheels are off the ground," it's NOT being flat-towed. Flat towing means all four wheels are on the ground, and you're pulling the vehicle with a tow bar.
I'd say the chances of damaging the actual steering system components are minimal with the rear wheels on a dolly, but it could put quite a load on the steering wheel lock mechanism.
Maybe there's another way to keep the steering wheel from turning that I don't know about. I've never had to have any of my own vehicles towed. My '58 Ford school bus broke down a couple times, but I drove off in the early-'50s Chevy spare bus as soon as the guys from the bus shop showed up.
I drive tow trucks on the side. I would highly advise against flat towing or even wheel lifting one of these cars. Flatbed rollbacks are really the safest way to go, the tow hook in the front is only for winching/ recovery purposes, not pulling at driving speeds.
I'm with Finewine on this one, to each his own. Just because a manual says you can do something doesn't mean you should. What happens if you break something at the track, steering column, control arm, tranny, flat towing or wheel lifting is useless unless you have tow dolly jacks, or a flat bed style towing setup.
Anytime you tow a vehicle without the tranny being fully disengaged meaning it can't effect anything should it go into gear you run the risk or hurting more then your trans. Say it slips into gear at 50mph being towed and the drive shaft is bolted up to your rear end, boom goes the rear, the trans and whatever else if you don't catch it quick enough. In 4x4 towing if there isn't a Neutral shift point, then we have to take the driveshafts out to ensure smooth and safe towing.
Yes a 350z with a standard transmission can be flat towed. They recommend to start the engine and let it idle for 5 min every 500 miles. Search for "Dinghy Guide 2004", the 350z is listed with instructions on what to do.
The 350z frame width is 920 mm or 36.2" outside to outside. The separation on the Amazon.com "GOFARAUTO BX1126 Tow Bar Base Plate, Compatible with 07-17 Jeep Wrangler and 07-17 Jeep Wrangler Unlimited (JK)" is 34.5". This costs only $309.99 USD. With a few strategic bends to make up 3/4" on each side, and some holes drilled in the frame, you have the missing piece.
There is no base plate made specifically for the 350z. There are two designed for the 370z. One is sold by:
https://www.etrailer.com/Base-Plate-...l?vehicleid=00
This sells for $592
-A good Flat Tow wiring kit for $99 is:
-A 350z base plate made from GOFARAUTO BX1126 Tow Bar Base Plate, Compatible with 07-17 Jeep Wrangler and 07-17 Jeep Wrangler Unlimited (JK): https://a.co/d/daQbaCl
Anybody that says Flat Towing will wreck a 350z, or that it cant be done, has not done their research. They are just plain wrong.
This sells for $592
The 350z frame width is 920 mm or 36.2" outside to outside. The separation on the "GOFARAUTO BX1126 Tow Bar Base Plate, Compatible with 07-17 Jeep Wrangler and 07-17 Jeep Wrangler Unlimited (JK)" is 34.5". This costs only $309.99 USD. With a few strategic bends to make up 3/4" on each side, and some holes drilled in the frame, you have the missing piece.
This sells for $592
-A good Flat Tow wiring kit for $99 is: -A 350z base plate made from GOFARAUTO BX1126 Tow Bar Base Plate, Compatible with 07-17 Jeep Wrangler and 07-17 Jeep Wrangler Unlimited (JK): https://a.co/d/daQbaCl
This sells for $592
The 350z frame width is 920 mm or 36.2" outside to outside. The separation on the Amazon.com "Camoo BX1126 Tow Bar Base Plate Tow Bar Bracket for 2007-2018 Wrangler JK JKU" is 34.5". This costs only $288.99 USD. With a few strategic bends to make up 3/4" on each side, and some holes drilled in the frame, you have the missing piece.
This sells for $592
A good Flat Tow wiring kit for $99 is: https://www.amazon.com/dp/B09XB1W6BQ...roduct_details
This sells for $592
