Is a TT Possible Look inside!!
Photos from the bottom side of the StrictlyZ 300ZXTT.
Note putting the Downpipes on Was a Pita.. I could barely fit a finger in there never the less a hand
The 350Z I almost bet you could pull the complete exhaust up to the heads without braking a sweat or a nuckle. There is plenty of room to Do a TT Conversion. =)
But the Biggest problem is will it be cost efficient? You would definatly need to change the pistons,ECU, Injectors Etc Etc ChaChing.. now my wallets empty..
Guest
Posts: n/a
You need custom: exhaust manifold, (2) t3/t4 turbos, (2) external wastegates, (2) bovs, complete dual exhaust pipes, (2) mufflers, a double intercooler, inter piping, (2) air filters, oil cooler, performance radiatior, electric fans, bigger injectors, fuel pump, programable ecu, gauges, forged pistons lower compresion, forged rods, forged crank, arp fasteners, cams,etc,etc... To do it right ,expect to spend a least 30k. Worth it maybe not but a good challenge hell yeah.
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
