Do 03' 350Zs have a tranny problem?
Old Jul 8, 2011 | 10:13 AM
Dr. Venture's Avatar
Dr. Venture
Originally Posted by vics350z
I have a 2004 auto transmissions Z and yes there feels like their is something wrong with the gears between 2nd and 3rd even in the auto you can feel the stuck or slip.
check your fluid levels.
Old Jul 8, 2011 | 02:59 PM
reserved's Avatar
reserved
Originally Posted by Dr. Venture
yes, nissans may have a synchro issue but mostly the issue lies with the driver not being able to find the gears correctly.
OK, driving a 6MT is not rocket science. To blame the driver for what is clearly bad design and engineering is complete BS!!!!!
BTW, I have been driving cars with manual transmissions for 40 years (yea, I'm old!!!!). Never a problem - until now
Old Jul 8, 2011 | 08:56 PM
Dr. Venture
are you 40? if so then you would have been driving probably for 24 years depending. lol....if you are older then i am wrong with this statement as well.
But being a known issue with Nissan then i stand corrected. otherwise it is mostly driver error.
my 03 performance 6mt has no tranny issues. And i baby her, drive her hard, and whip through gears like no other. Not one problem. I do however change my fluids every 20 k. perhaps that helps, perhaps it does not...who knows. As far as i know being 30....cept for the EVO previously destroyed by the old owner none of my vehicle, even the Z has had tranny issues.
Old Jul 13, 2011 | 10:59 PM
Mr. Nibiru's Avatar
Mr. Nibiru
MY 5th gear synchros went out. I couldn't shift from 4th to 5th without going at a 90 degree shift, unlike a 45 degree shift that is normal.
It's like the smoothness went out.
Old Jul 14, 2011 | 05:18 AM
PerfZ's Avatar
PerfZ
108,000 on mine and no issues whatsoever. Original clutch too. Luck of the draw, I guess.
Old Jul 14, 2011 | 05:37 AM
Dr. Venture
56k on mine. og clutch as well. Drive like Andriette. no issues.
(steel braided clutch line may be of help) the rubber line may with out you knowing loose some psi on the clutch allowing it to maybe cause the issue to worsen.
do al of you with the issues have steel braided or rubber??
Old Jul 14, 2011 | 08:03 AM
Lith's Avatar
Lith
Just out of curiosity, people that bought the 03-04's brand new, how many km's/miles did they put on the cars before they started experiencing the 3rd gear synchro problems and the clicking?
I have an 03 with 44,000km (~27,000 miles) and I don't have any of the problems described. Everything's original on the car. There are no mods on it (for now).
Also, what's the percentage of 03-04's that had transmission problems? (If that's even possible to tell).
Old Jul 14, 2011 | 08:13 AM
Dr. Venture
only "clicking" i experienced was from the axles. @ around 25 k. Simple fix is to remove and do a 180 deg turn on them and put them back in.
Old Jul 18, 2011 | 04:42 PM
carlosdurrah's Avatar
carlosdurrah
mine does not grind unless I try to shift very quickly. otherwise its fine for everyday driving. I plan on keeping mine as long as possible so I'll probably upgrade the tranny at some point anyway.
Old Jul 18, 2011 | 06:17 PM
JCat's Avatar
JCat
I'm on my 5th transmission in my z.
I am 54 years old and I have owned many vehicles with standard transmissions over the years.
It wasn't until I had the 009 model transmission installed until the problems went away. It has been in the Z for 20,000 miles now.
Best test is to get the Z up to highway speed, hold the clutch peddle in, and shift between the gears. If it grinds, it is a problem.
Old Jul 18, 2011 | 07:15 PM
MaelstrØm's Avatar
MaelstrØm
I see tons of diff cars daily and most of the synchro issues with many cars are driver error. Grinding gears and or some not even using the clutch to disengage if not at all to hardly clutching to begin with. yes, nissans may have a synchro issue but mostly the issue lies with the driver not being able to find the gears correctly.
Maybe on other cars, but here you don't know what you are talking about. I have driven stick for 20 years, and my prior transmission was smooth as glass and was great until I sold it at 120K miles. Within 8K miles of buying my 2003, the car was grinding into 3rd no matter how nicely I treated the shift. I even resorted to clutching in neutral first to stop it (which does work), but it is ghetto. I have a new CD009 and I hear a clank and click sometimes when shifting into 2nd, 3rd and 5th. It gets better when the tranny warms up - but the thing is new and hasn't suffered any mis-shifts in its lifetime. 4th gear has never done it.
The problem is the synchro design in the MT for this car. I have never driven an MT with such a rough feel before, and never one that clicks harshly into gear (without a grind) when it's brand new. I have thought long and hard about the fact that maybe the clutch throw is too short on the vehicle, or something that prevents the gears from fully disengaging. But almost nothing will make it smooth. So I just drive it like any other tranny and hope it won't fail.
Old Jul 18, 2011 | 07:18 PM
MaelstrØm's Avatar
MaelstrØm
I am curious - Dr. Venture, since you are a mechanic, what would cause this rough shifting (even before the grinding occurs). Is it the clutch fluid needs replacing? The clutch lines?
Old Jul 19, 2011 | 06:52 AM
ShOrTBu2's Avatar
ShOrTBu2
My 3rd & 4th are getting pretty bad, 3rd especially. I have to shift it in pretty slow to keep it from grinding. I'm way out of warranty and poor too so i'm really hoping to read changing fluids will get rid of it...
Old Jul 19, 2011 | 07:16 AM
JCat's Avatar
JCat
Here are pictures of what breaks: https://my350z.com/forum/4114331-post39.html
Old Jul 19, 2011 | 01:20 PM
reserved's Avatar
reserved
I am on my third. Don't get too complacent about the 009 transmission though.
Mine lasted two years (it comes with a Nissan ONE year warranty - probably says a lot about Nissan's confidence in it right there!!!!)
Old Jul 20, 2011 | 07:56 AM
pss350z's Avatar
pss350z
YES----------they do. The problem is the DRIVER!
I guess bad drivers are limited to the 03 and some 04s only then correct?
I had a tranny replaced on my 03 due to 5th gear grind.
Old Jul 20, 2011 | 08:19 AM
ZGus's Avatar
ZGus
Can't you just replace the bad synchro even if the problem will come again?
Old Jul 20, 2011 | 09:30 AM
  #38
Bret86944's Avatar
Bret86944
There is a common clicking noise with Z's, but it is the rear differential. It's my understanding it's not actually bad for the car, people just don't like the soudn. I have an 04.5, it has always made the clicking noise. I bought it at 33k, it's got 75k now.
Old Jul 20, 2011 | 10:47 AM
  #39
Michla22's Avatar
Michla22
Lucky myself as well With an 03: 161k mikes. Original trans and clutch - no problems.
Old Jul 20, 2011 | 12:09 PM
  #40
reserved's Avatar
reserved
I asked the same question.
I have been told (repeatedly) that it is more cost effective just to buy a new transmission. I guess labor costs on the rebuild are just too high.
