I got slip light on so easily!
Old Dec 3, 2011 | 08:23 PM
stonexu1984's Avatar
stonexu1984
Default I got slip light on so easily!
I have a 2003 350z. and I know rear drive car sucks in the snow weather but I am living in TX it doesn't snow that a lot
However, i found it slip more often than I thought even if on the dry road. specially when i accerlate and make turns (even if under 20mph) I never hard drive it. ANd the situation getting worse on the wet road - even if there is only a little bit wet, the slip light kicks in and I lost power the car shakes.
I am wondering is that normal for a rear drive car, specially for 350z? b/c I used to drive a 96 corolla which is fwd car and i can drive 70mph in raining day w/o problem. now i have to be like a grandma in raining day.
Also, if I turn off TCS does that help me a bit?
Thanks
Old Dec 3, 2011 | 08:40 PM
RENFRO's Avatar
RENFRO
Your old corolla isn't even on the same planet as your Z. Please for the sake of your future on the forums never compare the two again, lol.
The DE's are a torquey engine (more than the Rev-up and HR from the factory), I also can easily get the slip light to come on if I'm rolling into the throttle down around 20mph. RWD Sports car on wet road = being a little more cautious/aware of the way your car handles. Just tone it down a little if you feel you need to. I prefer to go a little slower in the rain with my Z to make sure I don't hit water I can't see and pull a 540 across the interstate.
For your own good lets keep that TCS turned on for now...get used to her first...if possible, go track it or hit up an autocross. Then cut your TCS off and see how she really does on the throttle and in the turns. It's how I got to know mine.
Happy Driving
Old Dec 3, 2011 | 08:46 PM
ambushphoto's Avatar
ambushphoto
Stock rims/tires?
Old Dec 3, 2011 | 09:02 PM
Way too subjective to give a constructive answer. What tires are you running? Miles on tires? Photos of tires?
Old Dec 4, 2011 | 12:40 AM
TehkMob's Avatar
TehkMob
Prolly need to get an alignment. Start there.. Out of toe can really make a car squirrely even more so in the rain.
Old Dec 4, 2011 | 05:27 AM
KornerCarver's Avatar
KornerCarver
It is amazing that people don't understand rear wheel drive automobiles. They drive fine in the rain and snow. Until the mid-1980's virtually all cars were rear wheel drive. People drove them in all kinds of weather without problems. You just need to learn to drive. Then you will be ok. My Z is a base without the electronic gizmos and I have no problem driving in any weather conditions.
Old Dec 4, 2011 | 05:33 AM
taywan's Avatar
taywan
turn the boost down!!!!!! i cant belive im reading so much on "how to drive cars" clutch, etc... u better keep that t.c. on before u end up in a ditch. especially in the rain
Old Dec 4, 2011 | 06:34 AM
DavesZ#3's Avatar
DavesZ#3
^^^ Exactly. Get some new rear tires (probably worn down) and learn to drive a car with power. Stay off the gas until you're headed in a straight line.
If you don't learn to get it under control, you'll be posting a thread like this one...
https://my350z.com/forum/maintenance...nksgiving.html
Old Dec 4, 2011 | 09:57 AM
terrasmak's Avatar
Need more info , is the car bone stock? Slightly nodded or heavily modded?
Old Dec 4, 2011 | 10:03 AM
huyrua's Avatar
huyrua
What mods do you have. Yeah turn off the TCS control, it's your car. Drive it anyway you want to. It's meant to be faster around corners vs your corolla. Post up parts-out in the near future.
Old Dec 4, 2011 | 02:08 PM
scruggyj's Avatar
scruggyj
Could have on the wrong size tires which is confusing the computer and turning your slip on.
Old Dec 4, 2011 | 02:50 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
Perhaps that isn't so wise given what OP has posted.
Old Dec 4, 2011 | 04:36 PM
R350Zz33's Avatar
R350Zz33
i can get my slip light to come on to yay im cool i can have it stay on all the way to redline and power through so im even cooler
Old Dec 4, 2011 | 04:43 PM
RMichael's Avatar
RMichael
I'm guessing you need to add some brake fluid. I'm assuming that dash is lit up like a Christmas tree.
Old Dec 5, 2011 | 07:45 AM
scotts300's Avatar
scotts300
What size - including width and aspect ratio - are your front AND rear tires?
For example: 245/35/19 front and 275/30/19 rear?
Old Dec 5, 2011 | 10:59 AM
stonexu1984
It's a touring, front 225/50/17, rear 235/50/17. I got this car 4 months ago not sure if the previous own had changed the tire or not. If it sounds abnormal then i should probably have it checked.
Old Dec 5, 2011 | 11:35 AM
scotts300's Avatar
scotts300
I believe touring had 18s, so you either have 18s or it's not a touring. Regardless, I'd bend over and check those tire sizes to be certain, then report back.
Old Dec 5, 2011 | 12:08 PM
Tire size is a bit unusual. Is your Z equipped with VDC?
Old Dec 5, 2011 | 12:15 PM
Surg's Avatar
Surg
I have gotten that also. And well within car and driver limits.
If the car is running ok listen to it. If not and you get a service
engine light do diagnosis. Could be a sensor, I got a code-PO335
CKP sensor. Crankshaft Position Sensor A malfunction. I changed
it and now runs fine but to quick around a corner and SLIP.
Old Dec 5, 2011 | 07:36 PM
BRONZEE's Avatar
BRONZEE
Club Moderator
If your car came stock, brand new with 17's, they did in some countries, those would be the correct specs for the stock 17's.
