2006-2008 Z owners help!
Old Feb 3, 2012 | 06:31 AM
rreisZ's Avatar
rreisZ
Default 2006-2008 Z owners help!
So I'm thinking about buying a 2006-2008 nissan 350z but I have heard some bad things about those years. I know they have the new VG35HR motors in it and people said that you may have oil consumption issues with those years.. Is that true? and how have those years been for you guys..? any problems?
Thanks!
Old Feb 3, 2012 | 06:35 AM
Pengu's Avatar
Pengu
The 2006 is the Rev-up so it's still a DE motor that a rev's a littler higher. It has about 14 more HP but has less torque. This is the year to be known to have oil consumption.
The 07-08 is the HR (High-Reving) and these are the probably the best years to buy since they have a little more HP, a high red line, and the best internals.
I have an 06 with no oil consumption and it runs great it has about 64k miles now and still going strong, I still check the oil levels halfway through before I need an oil change just in case though. My friend has an HR model is it's great and feels more responsive then my car though. If it was up to me I'd get the 07-08 Z if possible.
Old Feb 3, 2012 | 06:37 AM
LJ.Z's Avatar
LJ.Z
First off you didn't do the research. 07 and 08 are the only two models that come with hr motor. The 06 has the oil consumption problem.
Old Feb 3, 2012 | 06:43 AM
rreisZ's Avatar
rreisZ
Thanks alot bro. ill most likely go with the 07-08
Old Feb 3, 2012 | 06:44 AM
rreisZ's Avatar
rreisZ
Well i looked on some websites and people said the 06-08 have the new motors
Old Feb 3, 2012 | 06:48 AM
FacePalm717's Avatar
FacePalm717
What websites were they?
Old Feb 3, 2012 | 07:59 AM
PrimeX's Avatar
PrimeX
What is a VG motor?
Old Feb 3, 2012 | 08:39 AM
cgkp0925's Avatar
cgkp0925
Originally Posted by PrimeX
What is a VG motor?
+1
Old Feb 3, 2012 | 10:48 AM
Kcee91's Avatar
Kcee91
I guess he just mistyped it and said VG instead of VQ! lol No worries OP. For peace of mind, stick with an 07-08, but if you get an 07 check the vin number and make sure the clutch slave cylinder was replaced if the vin falls under the recall numbers. Good luck!
Old Feb 3, 2012 | 11:04 AM
I also heard bad things.
Old Feb 3, 2012 | 11:23 AM
e30cabrio's Avatar
e30cabrio
Just a rumor.
Old Feb 3, 2012 | 11:25 AM
Kcee91's Avatar
Kcee91
As far as the 06, my friend (350zbehold) has had no oil consumption when I told him to switch to Castrol Edge Syntec. He previously had Motul in there and it burned oil about all the time, but after he switched to Castrol he drove the car HARD and easy and still he has yet to burn a drop.
Old Feb 3, 2012 | 07:58 PM
graymetalicsilv's Avatar
graymetalicsilv
Get 07 or 08. The HR motors have much better lower end torque. But they use a concentric slave cylinder for the clutch, the cylinder is inside the bell housing. This makes it very expensive if you have to replace the cylinder since you have to drop the trans.
Old Feb 3, 2012 | 08:44 PM
clarkah's Avatar
clarkah
I thought the DE engines got more torque?
Old Feb 3, 2012 | 08:57 PM
PrimeX's Avatar
PrimeX
What? The HR motors have less low end TQ than the DE's. Read the forum or dyno's much?
Old Feb 3, 2012 | 09:03 PM
RMichael's Avatar
RMichael
what else is new?
Old Feb 3, 2012 | 09:43 PM
R350Zz33's Avatar
R350Zz33
bad things now you tell me after driving this damn pos car around for 3 years with 299.9 whp and 50k beating the crap out of it. so when do this bad things happen? jw
Old Feb 4, 2012 | 12:27 AM
Fenom's Avatar
Fenom
HR FTW!
Old Feb 4, 2012 | 05:13 AM
Frosty87's Avatar
Frosty87
Get a DE your modding everything is cheaper for them. Hr if your it keeping stock.
Old Feb 5, 2012 | 12:29 PM
rreisZ's Avatar
rreisZ
Thanks guys will most likely be getting an 07-08 Z
