12.5MPG. Why?
Old Feb 26, 2012 | 09:21 AM
silverbullet_Z's Avatar
silverbullet_Z
lowest I've seen my Z on my digital gauge was reading 2-3 mpg. But I was also going around a Track tho to lol But seriously under normal citing driving I don't recall my Z ever going below 14mpg. Highest I've hit was 30mpg all highway and one friend of mine with his SC vortech got 42mpg.....
Old Feb 26, 2012 | 10:14 AM
taywan's Avatar
taywan
True.
The short diatance and resetting odometer/calculate is the way to tell. Do u not let the car warm up before u drive? Especially begin that cold out? I wouldn't do that at all. And its not that cold here.
Old Feb 26, 2012 | 10:21 AM
secwind's Avatar
secwind
Could be the tires you're using as well. Heavier wheels and stickier tires equals less MPG.
Old Feb 26, 2012 | 06:41 PM
Suwaidi's Avatar
Suwaidi
I reset the odometer today and drove for 2 minutes and idled for 5 - It said I was at 2MPG. I reset it again, went on the highway and drove for about 20 minutes with minimal idle time, I got 20 MPG. So needless to say, idle time is calculated into our odometers.
Either do the gas fillup/calculation method or use your GPS to calculate it.
Old Feb 26, 2012 | 07:29 PM
mr. sparco's Avatar
mr. sparco
I wonder many mpg threads we have since '03.
Old Feb 27, 2012 | 11:27 AM
VMRWheels's Avatar
VMRWheels
Vendor - Former Vendor
Originally Posted by Waizzz
Because racecar
Short drives will always = poor fuel economy
+1
Never expect decent mileage from short drives.
Old Feb 27, 2012 | 04:56 PM
Ak48z's Avatar
Ak48z
Don't think I have ever seen mine below 17 but it usually sits around 20-24.
My daily drive is 10-15 miles each way though.
Old Feb 28, 2012 | 04:34 AM
4SHIZZIL's Avatar
4SHIZZIL
filled up thursday, saturday, sunday, and monday!
Old Feb 28, 2012 | 04:57 AM
350Zenophile's Avatar
350Zenophile
It always takes idle time into the calc, even if you do it manuelly. If you drive 19 miles while getting 23 MPG, then let your car idle till you burn off 18.2 gallons, fill up which will be 19 gallons then calculate it will be 1 MPG. Any time an engine is running, it will factor into your average MPG. The average MPG is what you get by manuelly calculating or by reseting the MPG gauge when you fill the car up.
Since we don't have a real time reading, the gauge reset while (steady state)driving can give you an idea. My Juke has real time, even with the cruise control set, it is all over the place.
^ THIS. It is supposed to take idle time into account or you wouldn't get an accurate reading. Do it manually as described above and you will be pretty damn close to the computer. Just be sure to reset it when you fill up so that you are averaging your mileage per tank vs. since last reset.
Old Feb 28, 2012 | 05:45 AM
*ICE*'s Avatar
*ICE*
there is an app for that
Old Feb 28, 2012 | 06:18 PM
Modrummer's Avatar
Modrummer
Originally Posted by elguaje909
I dont know how you people drive , i just got a 2007 350z Speed manual i drive to work every day which is 20-24 miles away and i get 31 some times 32 MPG its all how you drive how you shift and the speed that you travel in i shift at 2k rpm until im in 6th gear then i just take it easy i drive 66-70 on the freeway. change your driving habbits and maybe you will see better mpg
Agreed. Although its more like 27-28 mpg for me.
Old Feb 28, 2012 | 07:34 PM
ronn1's Avatar
ronn1
Originally Posted by romnation
2003 5AT.
A lot of my drives are short 0.8 mile drives to campus and back, usually hitting plenty of traffic lights along the way, but 12.5mpg? really? I even try to drive conservatively. Should it really be this low? Even when I mix in a few drives that are like 3 miles there, 3 miles back, my gas mileage doesn't really go up. This car doesn't get a lot of highway mileage anymore, as I'm in a college town. Dealer said everything on the car looks fine (air ratios and whatnot) It is cold here right now (30 degrees)
Short stop and go milage and little FWY (sustained driving) will give you that MPG. That's what I get. Do this simple test. Reset the computer for MPG and drive it on the FWY at a steady 65 or so for 20-30 miles. You should get 23-24. If it's much less, then you have a problem.
Old Feb 29, 2012 | 03:15 AM
terrasmak's Avatar
When you car is cold, it dumds more gas trying to get the motor to operating temp, when your trip is 2-3 miles you are in that mode the whole time. Typically i average 23 with mine (a bit less with the GT wing now) but over the summer I went to a school for 6 weeks where my daily drive was 2 miles each way, with a 25 mph speed limit. With only going to school and not leaving the base i averaged 12 to 13 mpg.
Stop and go burns gas
Open loop operation (not warmed up ) burns gas
Low speeds burn gas (optimal speed is around 60 mph) burn gas.
Old Feb 29, 2012 | 05:26 AM
KornerCarver's Avatar
KornerCarver
2003 5AT.
Since your drive is so short............why not just walk? That would be good for your health and good for the environment.
Old Feb 29, 2012 | 12:22 PM
joshie3.5.0.z's Avatar
joshie3.5.0.z
im at about 18-20 on my hr-z cruising to work 8 miles from home. I herd the gauge are never really that accurate
Old Feb 29, 2012 | 01:05 PM
ronn1's Avatar
ronn1
You mean the MPG computer or the gas gauge? Gas gauge is *iffy*, but really doesn't effect calculations as long as you run it down to empty light on fill up to determine gas used. I find computer MPG pretty accurate (compared to calculating on tank fill up results which is really the way to go) as long as ya aren't idling a lot of the time.
Old Feb 29, 2012 | 05:26 PM
joshie3.5.0.z
Yeah I forgot to put mpg
Old Feb 29, 2012 | 06:42 PM
  #38
Zredman's Avatar
Zredman
lowest ive gotten was 17 and ive had weeks its nothing but city driving with traffic, and others with highway 60-70-80 mph all the way, or that blasted rush hour traffic which takes an hour to go a mile some days. when i got 17 mpg that included driving like I had just stolen the car. The gauge that calculates mpg doesnt do to great with short distances. its about 90% within 1mpg when i do alot of highway and little city. compared to being about 40% right with stop and go traffic and heavy city, a few times it was 3 off, big diff from saying 17 and it was 20.
Old Mar 3, 2012 | 09:07 AM
  #39
dvsone's Avatar
dvsone
EVAP System can be throwing your readings off or if there is a leak in the EVAP it can cause your MPG to go down about 6-11 mpg. Mine dropped to that when I had a leak in the EVAP. Check into it and GL !
Old Mar 3, 2012 | 10:16 AM
  #40
JedixSole's Avatar
JedixSole
im 14.8mpg on 03 track. i barely drive it too.
