coup/vert same performance?
HI everyone..
I was curious if there is a big difference in performance between the coup and convertible 350z? It seems the convertible is expensive, but I think a good deal can be got from the coupe. Thanks.
I found the vert to be sort of dissapointing to drive. thanks.
from my J A C K A S S opinion. im thinkin in a drag. "DRAG" race the coupe might be better off? well i say this because the coupe has lower weight then the convert. but i think the convert has traction control? am i correct? i dunno if it helps on a drag. but i dunno... its jus my opinion. but if i had the money id go wit the convert~
again, not a professional opinion,
jus a J A C K A S S opinion
I would expect slight edge over the coupe, but... Probably not enough to matter in real world performace. Less flex, less weight.. Coupe has the edge.
If you were diappointed by the convertible for whatever reason, doubt the coupe would do it for ya..
Tochigi_236
Sep 27, 2015 03:40 PM
