Car Storage - Specific Question..
Old Nov 15, 2012 | 04:50 AM
oldschool350z's Avatar
oldschool350z
Default Car Storage - Specific Question..
Is it better to start my car and let it run or simply not start and let it sit.
I have fuel stabilizer in the tank and fuel lines, and will change the oil first day it's on the road.
Just curious which is a better practice to do. I'm also charging the battery periodically.
Old Nov 15, 2012 | 05:00 AM
Z PHAT Z's Avatar
Z PHAT Z
There is a sticky thread about storing the Z. No fuel stabilzer, no starting the car, get the tires on a mat. Get a battery tender or unplug your battery. Filled the gas tank, inflate the tires a bit higher than 35psi. That's what i remembered. But read that thread and you see what other people do.
Old Nov 15, 2012 | 05:12 AM
cgkp0925's Avatar
cgkp0925
https://my350z.com/forum/maintenance...-winter-2.html
/thread
Old Nov 15, 2012 | 05:33 AM
JCITY's Avatar
JCITY
How long are you planning on storing your car?
I've found its better to start&run the car periodically than
let it sit.If you are talking about leaving your car unattended
for several months,then I'd add air to the tires,run some fuel
stabilizer through the engine(I use Stabil),disconnect the battery
or have a trickle charger attached to the battery.If your storage
is a longer term,I'd put the car up on jack stands.
Old Nov 15, 2012 | 06:31 AM
Z PHAT Z's Avatar
Z PHAT Z
JCity,
I suggest you read the thread posted above
etkms
Jun 19, 2022 06:30 PM
sales@czp
Suspension
54
Jan 17, 2018 09:24 PM
jlb
Oct 15, 2017 05:10 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
SpartanZ32
Oct 22, 2015 09:36 AM
