WTF?!
Old Nov 30, 2012 | 04:10 PM
SoCaL_ZLoVeR's Avatar
SoCaL_ZLoVeR
Default WTF?!
I was driving home in the rain and I had a 1/4 tank, then 2 miles from my house I see that my gas needle was going down rapidly.. And my DTE was at 66, then a few seconds later it was at 54, then 47, all the way down to 34 once I got home.. I know the gas gauges are tweeky, but this was just weird.. I'm not leaking or anything either. Anyone know what happened?? It's raining also, if that means anything..
Old Nov 30, 2012 | 04:11 PM
SoCaL_ZLoVeR
It's an 04 btw
Old Nov 30, 2012 | 04:19 PM
KornerCarver's Avatar
KornerCarver
I don't think it is anything to get too worried about. I would just fill the gas tank and get on with life.
Old Nov 30, 2012 | 04:30 PM
enZus's Avatar
enZus
Don't worry about it, never trust the dte from the computer, its just the gas moving back and forth in the tank
Old Nov 30, 2012 | 05:01 PM
taryon's Avatar
taryon
Yeah the DTE is pretty glitchy. I went from 1/4 of a tank to nothing (something like 60kms to 15kms) in 2 minutes driving up a steep hill.
Old Nov 30, 2012 | 05:09 PM
WTFMike's Avatar
WTFMike
Yes????
Old Nov 30, 2012 | 05:38 PM
Arvin89's Avatar
Arvin89
One time my gas light came on when i got home. When i started it the next morning i had 1/4 tank left...
It happens. If you fill up and it continues to drop at that rate then be worried.
Old Nov 30, 2012 | 05:44 PM
hugo350z's Avatar
hugo350z
Like mentioned before me, gas in the tank splashes around giving a faulty reading. Also the road angle(elevation; incline or decline) will change what the fuel gauge reads.
Old Nov 30, 2012 | 07:12 PM
terrasmak's Avatar
Happens all the time
Old Nov 30, 2012 | 07:33 PM
805350z's Avatar
805350z
Your car is broken.
Old Dec 1, 2012 | 02:51 AM
taywan's Avatar
taywan
I think there's a thread about cleaning some part of the fuel pump that may help.
Old Dec 1, 2012 | 06:22 AM
BoomerZ33's Avatar
BoomerZ33
it's never truly accurate
Old Dec 1, 2012 | 06:37 AM
Waiz's Avatar
Waiz
It's an estimate, depending on how you're driving
Old Dec 1, 2012 | 09:59 AM
Rokyr's Avatar
Rokyr
This would never happen in an RSX.
Old Dec 1, 2012 | 07:05 PM
resident25's Avatar
resident25
DTE is somewhat inaccurate at times. It's no big deal man. Fill that sucker up and get on with life!
Old Dec 2, 2012 | 07:05 PM
Sarahs350Z's Avatar
Sarahs350Z
Whenever I park on an incline the needle will drop but once I get on a flat surface it'll level out. If the hill was steep enough that could easily be the cause.
don't worry!
Old Dec 3, 2012 | 08:31 AM
Phenom's Avatar
Phenom
Toasty
Did you forget to put diesel in it?
Old Dec 3, 2012 | 09:30 AM
RewiredZ's Avatar
RewiredZ
I had this exact same problem! I had to reprogram my key fob, pump the gas 5X, turn on the high beams, 2X brake pumps, turn off the high beams, then filled the tank, and it fixed it.
Old Dec 3, 2012 | 09:46 AM
flynzed's Avatar
flynzed
Wow! You found the short method for correcting the gas gauge status error. If I only new I would have left off the step where you put the rear of the car on jack stands while holding the gas and brake pedal singing if I only had a brain.
Old Dec 4, 2012 | 12:47 PM
WEARERAD1CAL's Avatar
WEARERAD1CAL
I always just fill it when it gets to 1/4 for some reason. I did that before I even knew there were problems with the gas needle.
