having problems
Old Dec 12, 2012 | 06:35 PM
electricbluez's Avatar
electricbluez
Unhappy having problems
hey my z has been making a hovering sound every time im driving. when i accelerate it comes on at 30 miles an hr and also when i am going 70 it sounds like its the back tire i have no idea what it is.. any suggestion???
Old Dec 13, 2012 | 09:55 AM
TPete19's Avatar
TPete19
I have no idea what a "hovering" sound is. Sound sare hard to diagnose over a forum, so best to either record the sounds for us or just take it to a shop.
Old Dec 13, 2012 | 10:19 AM
35thannyZowner's Avatar
35thannyZowner
The first thing I would do is look underneath the car. If you ran over a tree branch (or anything else), and it got hung up underneath it could make that kind of noise. If there is nothing obvious, then it could be the transmission. If automatic, it could be low on transmission fluid. Beyond that, a mechanic would be your best bet.
Old Dec 13, 2012 | 10:35 AM
35thannyZowner
On the other hand, if you are unable to find the problem, and the hovering sound persists, then your next best option would be to look on the roof to see if anyone has painted words like "Police Helicopters Eat Twinkies".
Old Dec 13, 2012 | 11:17 AM
PerfZ's Avatar
PerfZ
Bad tire more than likely. From the description sounds like the old feathering problem, although that was only on front tires.
Old Dec 13, 2012 | 11:56 AM
harman850t5's Avatar
harman850t5
Wheel bearing?
Old Dec 13, 2012 | 12:03 PM
35thannyZowner
Possible. No, it's not just the front tires that can be out of line. The rear axles are independent, and require Camber & Toe-in adjustments. The Caster can also be affected if the rear axles are not "trailing" properly. Here is a link to Factory Service Manuals: http://www.courtesyparts.com/owners-manuals.php
I hope that helps...if not, check the roof.
Old Dec 13, 2012 | 05:28 PM
Phenom's Avatar
Phenom
Toasty
Hovering? Your Z has achieved take off.
Old Dec 13, 2012 | 07:03 PM
stuartc323's Avatar
stuartc323
lmao i also see this is your first post OP, is this hovering sound not just wind hitting the cabin at those speeds? the Z is a little noisy in the cabin
Uriyo_
Sep 8, 2021 08:46 AM
