New 350z mods
Old Dec 20, 2012 | 07:46 AM
calebcorbin's Avatar
calebcorbin
Default New 350z mods
Hey everyone,
I've had my Black 03 Z for about a year now and I am absolutely in love with it. It now has 105k miles and the 2-3 and 5-6 gears were grinding pretty often. It was becoming difficult to shift all around so I ordered a replacement cd009 tran. While I was at it I ordered stillen SS headers, Borla true dual exhaust, and a jwt pop charger.
I will post updates when I get them installed, probably next week.
I've been following this site for a while and just wanted to join and say hey
Thanks!
EDIT:
Ended up going with the borla TD, Z1 test pipes, z1 high flow intake, z1 clutch/flywheel combo, ss stillen headers, and cd009 tranny.
Took about 12 hours for everything with lifts and two men.
Last edited by calebcorbin; Dec 27, 2012 at 04:50 PM. Reason: Used different parts.
Old Dec 20, 2012 | 07:56 AM
myzproject's Avatar
myzproject
Welcome to the boards
Old Dec 20, 2012 | 07:58 AM
terrasmak's Avatar
I would do a clutch and flywheel while its apart
Old Dec 20, 2012 | 08:01 AM
PerfZ's Avatar
PerfZ
^^^^Likewise. I've got 128,000 on my original clutch but I seem to be the exception and you will save quite a bit in labor by doing it at the same time.
Old Dec 20, 2012 | 08:40 AM
calebcorbin
I appreciate the advice.
I thought about going ahead and doing it while its apart but the $600-800 for the set up I want is just a little much considering what I just ordered. mine is performing well at the moment.( fingers crossed) The labor isn't a huge deal because a family member of mine owns an auto shop and will help me for free at his shop.
Old Dec 20, 2012 | 08:42 AM
daytonabluez05's Avatar
daytonabluez05
Welcome, post pics of your Z when you get the chance too, and yea im with them i'd do clutch and flywheel at the same time.
Old Dec 20, 2012 | 08:44 AM
JCITY's Avatar
JCITY
welcome to the community!
Just my opinion based on experience,the headers are a waste of time and $.
You won't notice much difference.The Borla is great.But a better choice for your
exhaust system would be HFC's.Plus,I'd add a plenum spacer.Then get your car tuned.
Z1 Motorsports in Carrollton is one of the best in the country.
Old Dec 20, 2012 | 09:01 AM
bmccann101's Avatar
bmccann101
yep, headders when FI, stock w out. Other mods are far better suited to the car.
Welcome. btw, that transmission can be found lightly used for 5-750 bucks usually. Hope you didnt opt for a 1600 new one. Youll need the entire tranmission tho, including the shifter brackets etc.. they are quite different between the two transmissions.
Thats just my opinion tho.. make sure the shifter is realigned using the Nissan process most ppl think they just bolt right back in, not the case.
Old Dec 20, 2012 | 09:21 AM
calebcorbin
I will deffinitely take your advice on the HFC's.
I ordered a new one from Z1, should it have all the parts I need to swap it out? I thought it was a direct replacement.
Thanks
Old Dec 20, 2012 | 12:33 PM
JCITY's Avatar
JCITY
Thumbs up Direct replacement
Thanks
Yes,has all the parts and a direct bolt on.Have you swapped out cats before?If you don't
have the tools,its a bit time consuming.Especially getting at the
front stud.What area do you live?I'm running Z1 HFC's.Had them do the
install.They have all the tools& do them everyday.Rather than taking a weekend of busted knuckles,I paid less than 100 bucks to let Z1 do it and
get a tune at the same time.Possibly you are in a area of the state thats
not close to Atlanta?In addition,the Z1 HFC's are just as good or better
than the "name" brands for a lot less.
Old Dec 20, 2012 | 12:39 PM
txmad's Avatar
txmad
damn ... how much did u pay for all of that ?????
Old Dec 20, 2012 | 09:15 PM
calebcorbin
Haha I've spent about $4500 now since I ordered a z1 clutch/flywheel combo.
Thanks for the recommendation on the hfc, I am familiar with z1. Planning on going there for a tune.
Old Dec 20, 2012 | 10:06 PM
calebcorbin
I ended up going with the z1 motorsports test pipes for $180. Great deal I think.
Old Dec 20, 2012 | 10:20 PM
stuartc323's Avatar
stuartc323
nice mods, welcome to the forums get it dynoed if you have enough while your down there after the tune!
Old Dec 21, 2012 | 06:39 AM
Nismo350z#0310's Avatar
Nismo350z#0310
Def. will need the tune
Old Dec 21, 2012 | 07:51 PM
Fenom's Avatar
Fenom
try to get a tune to maximize the power gain by breathing mods
Old Dec 21, 2012 | 08:27 PM
NismoZ123's Avatar
NismoZ123
Haha. Get 12 hp back by cleaning/changing the air filter once or twice a month.
Old Dec 23, 2012 | 06:03 AM
QuintonC's Avatar
QuintonC
THIS.
I recently bought a JWT clutch and lightweight flywheel, and I'm being dead serious when I say that I wish I would've done it when I got the car. While you're doing everything else, I would highly recommend it. Does not lose any comfort and grabs hard. Also the lightweight flywheel makes a night and day difference.
Old Dec 27, 2012 | 04:36 PM
calebcorbin
Default Pics
Finally done
Old Dec 27, 2012 | 04:37 PM
calebcorbin
Default More
More pics
