Dd coilovers
on
Yes but depending on the age and or miles on your Z you could use this time to swap out your stock bolts. Not needed unless the looked stripped or something. I did it with my Tein coils so everything was the same age
on
Ok guys ive searched hours and hours in the forum to find the best set up for my dd Z but i juz got confused and got a major headache. Basically all i want is comfortable ride with about an inch drop. My car will never see the track or drag. My car is an 08 bone stock except for spacers 25 front and 30 rear, eventually i will replace my tires with bigger and fatter tires my stock wheels would allow me thanks for the input guys. My budget would be no more than $1500
BC racing
Stance
Megan
D2
$1500 budget for show and performance
Eibach
KW V1
Buddy Club
Truechoice
Fortune Auto
$1500 budget for performance
Koni Yellows
Threaded perches front, Spring Adjusters Rear
500 spring rate front, 475 spring rate rear
Lol i am in houston, sorry for the noob question but for the koni do i need to buy separate lower springs? Or does it come with it? And the tokico i noticed its only for de but juz like u said maybe the one for HRs are out of stock
If i need to buy a separate set of spring will the this springs would work juz fine right? Because im planning on getting the sways anyways
http://www.importpartspro.com/804131.html
If you want to set this up right, first grab shocks than take your stock system to the limit on a track to determine what you need to upgrade next which will probably be sways or springs, should be springs though. The stock system is setup very well and very few ever take it to its limits to understand how good it is.
Your plan should be:
Shocks
Springs
Sways
Bushings
Camber kits if your trying to go lower than 1"
if your trying to just be low and look good, grab any option from the first list i gave you.
08-06-2021 06:19 AM
04-04-2016 07:52 AM
