Is $400-450 a reasonable price for master/slave cylinder replacement?
Old Sep 20, 2013 | 08:29 PM
superstuddc27's Avatar
superstuddc27
Default Is $400-450 a reasonable price for master/slave cylinder replacement?
My clutch pedal is sticking and not coming up all the way. A shop quoted me $400-450 to replace the master and slave for the clutch. He said it was a rough estimate and he would need to call me back when the parts are in but he wrote an invoice for me that says around $430 or so. Put down a deposit of $60 and left the car there.
Is this a reasonable price to swap out both? I read there are rebuild kits but I really don't have the time, space or energy to try to figure that one out, rather pay someone to do it and warranty the work.
I called a place near my house that works on racing and imports exclusively and they have good reviews for quality work but i think the guy was lying to me or just trying to charge me an insane price. He said the labor to do the slave was $900. Then he said I need to do both because otherwise we'll have to bleed twice. master and slave cylinder for the clutch is around $300-350 for the parts alone so we're looking at at least $1200 out the door. He also said you have to drop the tranny to reach the slave and while we're there, might as well do a clutch. Clutch job is $1000 including resurfacing the flywheel.
I already know this guy is full of **** but he was nice so i said thanks and hung up. He said there was a Z there last week with the same problem.. $350 for parts only for the master and slave? $900 for the labor. What a load.
What did everyone get charged when they changed out the master and slave?
I am reading it's most likely the master cylinder that is causing the problem with the pedal sticking and given that it's a common issue with our cars it sounds right but if I got quoted $430 to do both, it sounds ok to me.
Old Sep 20, 2013 | 08:36 PM
Bmurray350z's Avatar
Bmurray350z
I just paid $450 (labor) to have a clutch/flywheel/master/slave replaced. Upgraded to the ZSpeed CSC and the Wilwood master, which ran me $490 together. So essentially $1040 in parts & labor.. but there was a clutch/flywheel kit installed as well. I think $430 just for master/slave install is a little much.
Old Sep 20, 2013 | 08:42 PM
terrasmak's Avatar
What year is your car ?
06 and older $35 total for rebuild kits, takes me less than 2 hours working in my home garage. I would do it for $100 , for local Z owners.
Old Sep 20, 2013 | 08:43 PM
superstuddc27
I just paid $450 (labor) to have a clutch/flywheel/master/slave replaced. Upgraded to the ZSpeed CSC and the Wilwood master, which ran me $490 together. So essentially $1040 in labor.. but there was a clutch/flywheel kit installed as well. I think $430 just for master/slave install is a little much.
Oh well it's $430 for the labor and parts actually. not sure how much the cylinders cost though.. if they total like $200 or even $350 like that one guy said then they'd be doing it for like $100 which wouldnt make sense to me but if they'll do it I'll take it.
Old Sep 20, 2013 | 08:46 PM
Bmurray350z
Oh if its $430 for parts and labor then I guess it's not too bad. However you may get the same problem down the road with the sh1tty oem slave cylinder
Old Sep 20, 2013 | 09:01 PM
BigBlue's Avatar
BigBlue
Yeah, I think the CSC is about $340, $175 or so for master; something like that.
Old Sep 20, 2013 | 09:03 PM
BigBlue's Avatar
BigBlue
Maybe I could hit you up; hang out at a nice casino, give you a $100 tip and maybe have a little fun to boot!
Old Sep 20, 2013 | 09:11 PM
terrasmak's Avatar
07-08 is a little different story. The older Z I don't have to drop the trans to do a slave.
Old Sep 20, 2013 | 09:34 PM
superstuddc27
It's an 05. But dont you have to drop the transmission to get the slave cylinder? Or were you referring to just rebuilding the master? I wouldn't mind that at all as long as it fixes the sticky clutch pedal issue. I read somewhere I can get a $15 rebuild kit from fontana nissan if I'm not mistaken?
Are you near Orange County?
If it'll fix the issue, then I would rather do that even though I put down a $60 deposit. Beats $450 when money's tight
Old Sep 21, 2013 | 12:22 AM
MisoHoni's Avatar
MisoHoni
I 2nd that. Helped a friend change clutch/flywheel on his 08. Takes some time
Old Sep 21, 2013 | 05:22 AM
MadCow's Avatar
MadCow
I believe there was a recall regarding the clutch slave cylinder. You may need to verify whether is apply to you 05.
Old Sep 21, 2013 | 05:28 AM
Bmurray350z
Pretty sure that recall was only on 07-08
Old Sep 21, 2013 | 09:13 AM
terrasmak's Avatar
06 and older is an external slave , 2 bolts and the line, come right off. Very simple to do.
Old Sep 21, 2013 | 10:59 AM
superstuddc27
Oh really? So I guess the shop wasn't crazy to charge me $430, I was thinking he would never do that if he needed to drop the transmission.
The other shop I called however, lied to me I guess or was misinformed.
I guess it's better for me that it's external.
Old Sep 22, 2013 | 04:36 AM
HK350 Z's Avatar
HK350 Z
The other shop I called however, lied to me I guess or was misinformed. I guess it's better for me that it's external.
Yes, you dont want the internal slave, trust me...
Old Sep 22, 2013 | 09:12 AM
calidrew909's Avatar
calidrew909
I just did clutch flywheel and zspeed performance clutch master cylinder and the labor was 400 for everything I brought the parts , don't go with oem or rebuild get aftermarket and for 350z everywhere I've reaearch said your not supposed to put the same flywheel that you already have buy a new one
Old Sep 23, 2013 | 06:40 AM
PerfZ's Avatar
PerfZ
Both slave and master on an '05 are two bolts and one line removal/replacement. IMHO $400+ is a ripoff for what should be an hour of work. Upgrade to the ZSpeed Willwood kit though.
Old Sep 23, 2013 | 07:05 AM
travlee's Avatar
travlee
Master
i paid $800 labor to have mine swapped in the HR....
Old Sep 23, 2013 | 10:56 AM
superstuddc27
damn.. well i put down an $60 deposit and the parts should be here tomorrow. he said to come in on tuesday and he'll do it. Too late to change now I guess, I made the decision under the impression the pricing was average or normal..
Old Sep 23, 2013 | 11:07 AM
travlee's Avatar
travlee
Master
if you have a DE, it wont be that much... should be reasonable
