Steering wheel noise
Old Nov 3, 2013 | 12:38 AM
Lonestarr350's Avatar
Lonestarr350
Default Steering wheel noise
I just recently starting hearing like a screechy sound when I turn my steering wheel to the left .. Does anyone know what or why it does it?? I have an 07 Z please help!
Old Nov 3, 2013 | 01:11 AM
winchman's Avatar
winchman
We definitely need more info on the symptoms and on the car itself.
Most likely cause of steering-related noise is the serpentine belt slipping. That'll be coming from the front of the engine. An '07 would have to have lots of miles for that kind of problem, though.
Old Nov 3, 2013 | 09:06 PM
Lonestarr350
It doesn't seem like it comes from the engine .. It sounds like it would be right under like my dash and all that .. I mean there isn't any other symptoms .. Just like a screechy type noise when I turn left .. I have 48k miles on it
Old Nov 3, 2013 | 09:37 PM
winchman's Avatar
winchman
Have you tried adjusting the position of the steering wheel to see if the noise goes away?
Does the horn and all the buttons (if any) on the steering wheel still work? Thinking clock spring issue, maybe.
Old Nov 3, 2013 | 09:43 PM
Lonestarr350
I haven't tried that .. I think I will try that tomorrow ... If it is the clock spring .. Would that be hard to fix?
Old Nov 3, 2013 | 10:57 PM
samsniss350z's Avatar
samsniss350z
I agree with Winchman, the first of my S14's did this at first it was only when I started the car and after about 10 minutes it stopped, but gradually got worse. Funnily enough it was worse on damp mornings (about this time of year) and only stopped when I adjusted the belt.
Old Nov 4, 2013 | 08:23 AM
Lonestarr350
That's exactly what happens with mine after like 10 min it stops .. How do you adjust the belt ?
Old Nov 4, 2013 | 08:41 AM
stuartc323's Avatar
stuartc323
I believe the Z has two adjusters one on the bottom and the top for the serpentine belt, but check out this thread
https://my350z.com/forum/engine-driv...t-for-hrs.html
you have been officially spoon-fed
Old Nov 4, 2013 | 09:03 AM
Syner's Avatar
Syner
Obadabot
Jun 18, 2023 11:31 PM
