Wheel bearings?
Old Sep 30, 2015 | 09:53 PM
Obadabot's Avatar
Obadabot
Unhappy Wheel bearings?
Hello guys, so I've noticed a funny noise while driving my car, this has been going on for about a week now. Every time my car is rolling for example when I'm slowing down I hear a "do do do" sound sort of like a helicopter ( idk if anyone is gonna understand that lol). This noise is coming from the front passanger wheel, I suspect it is a worn wheel bearing? If im not wrong, can anyone tell me the best price I can get these for, and where ?
Old Oct 1, 2015 | 07:04 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It's not hard to check- just jack the car up on that side and see if there's any axial play on that particular wheel. As for price, check your local sources with a bigger retailer like Rock Auto to see what prices are currently.
Old Oct 1, 2015 | 08:14 AM
dcains's Avatar
dcains
I can only add a warning about a vendor like rockauto, for certain types of parts. Don't use chinese-made parts. I'd look to http://www.courtesyparts.com/350z-pa...008-c-714.html for OEM Nissan parts in this case.
Old Oct 1, 2015 | 10:50 AM
rancor's Avatar
rancor
If I am not mistaken rock auto does sell the OE suppler TIMKEN? in both the front assembly and rear bearing.
Old Oct 1, 2015 | 10:53 AM
dcains's Avatar
dcains
You may be right. One some items they give you a few choices and you can pick the brand you prefer.
Old Oct 1, 2015 | 12:21 PM
dphoenix's Avatar
dphoenix
make sure you buy TIMKEN brand, I had mine replaced awhile back. I believe TIMKEN is the brand Nissan uses for OEM bearings.
Old Oct 1, 2015 | 05:44 PM
RWDBajan's Avatar
RWDBajan
Did you check for tire bulging?
Old Oct 3, 2015 | 12:07 PM
guitman32's Avatar
guitman32
Ive never seen a Timken stamped bearing on a oem 350z. Ive only seen SKF/NTN on wheel bearings, diff inner and outer pinion bearings, and diff bearings. Just my experience anyway, and it can definitely vary from production run over run.
Old Dec 15, 2015 | 07:26 PM
Joe clan's Avatar
Joe clan
So did you end up doing new bearing? Did it get rid of the noise?
Old Dec 15, 2015 | 08:37 PM
dkmura's Avatar
dkmura
Good luck getting any response from OP. He posted almost three months ago, checked back the following day, and never came back after that...
Old Jan 20, 2017 | 03:36 PM
Obadabot's Avatar
Obadabot
A year later... im not really good at this forum stuff. I appreciate anyone who helped. but yes i ended up getting new wheels bearings for the front, with OEM parts.
Old Feb 16, 2017 | 04:41 AM
DanielProudfoot's Avatar
DanielProudfoot
I had the same noise.. ended up being a metal band broke in my front passenger tire. New tire no noise.
Old Feb 26, 2017 | 06:02 PM
SM0KESCREEN's Avatar
SM0KESCREEN
What's the typical price on that repair?
Old Nov 6, 2019 | 05:48 PM
akuma69's Avatar
akuma69
Default Solved it!!
EDIT: Deleted. Posted in wrong thread.
Last edited by akuma69; Nov 6, 2019 at 06:13 PM. Reason: EDIT: Deleted. Posted in wrong thread.
Old Nov 6, 2019 | 06:05 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Annnnnnnnnnnnnnd..... from wheel bearings to radio in-op fix in one swell foop!!!
Old Nov 6, 2019 | 06:11 PM
akuma69's Avatar
akuma69
oh that's weird how my post appeared in this thread. I'll update.
Old Jun 18, 2023 | 11:31 PM
Gassaloglu's Avatar
Gassaloglu
I had a similar issue, same wheel, but it was a ticking sound. The Steering Balljoint boot was cracked and needed replacements
irbullet
Aug 15, 2016 05:13 PM
Quellos
Feb 5, 2015 10:20 AM
djtimodj
Jul 19, 2009 10:09 AM
Exiled Lakai
Jun 25, 2008 03:45 AM
Seel
Jun 21, 2007 06:38 PM
