The Z seems hard to improve on....
Ok but I'm just saying that the title of your thread is based on the Z being 'hard to improve on'. As far as power production is concerned, if you stay the N/A route, it will CONTINUE to be hard to improve on.
FI parts do not add that much weight and good turbo systems can spool up very quickly and any lack of the N/A response you are used to will be MORE than replaced by the huge surge in torque that turbos can provide.
Also, the CHewbacca sound of the car, as you put it, is probably not from the headers but the design of the exhaust canister. When I went to a TurboXS exhaust which has the same look as a stock facotyr exhaust (transverse-mounted canister), the sound of my car completely changed.
And the Chewbacca sound is def not limited to the stock exhausts. The sound changes, but it still has a weird warble I'm just not crazy about when the two streams merge. It's way less prevalent in cars with headers and HR cars which makes me think it's something to do with the headers.
Bolt-on horsepower will be tough. Buy every possible bolt-on and you may get an extra 3 percent horsepower. Pretty expensive for 3 percent.
Suspension is another matter. I went with the NISMO suspension and improved my autocross times. Trade-off was teeth jarring ride on the street.
There is always a trade-off.
OP, to what end are you looking to mod the car?
I have been tracking my car for ~8 years. I have changed a good bit on the car, but I have yet to try an add any HP.
Improving handling comes with reasonable costs, but bolt-on HP gains cost way too much for what little you get IMHO.
Sounds like the OP wants instant/easy power on a low budget, has no course of action and is stuck between a rock and a hard place with the DE. Change out the final drive, best bang for buck.
People will eventually get bored of their N/A power. Hell, even me, a relatively mild kinda guy, is getting slightly bored with my turbo set-up.
I think if you're gonna go the N/A route, you need to do something like Rickdogg did which is a gutting of the car, corner balancing etc.
I am kind of disappointed with the differential bushings. I just had mine go this past month about right on about 7 years. I upgraded with solid differential mounts and energy suspension sub frame, poly trans mounts, and poly engine mounts and there is a major increase in performance. There is more noise and vibration but it is one of the most noticeable mods I have done. this car doesn't even compare to the way it drove before differential bushing blew.
You make it sound like all turbo-equipped cars are lethargic diesels. It's 2014.
I just don't like turbos. I'd rather "waste" that money on N/A parts and making the car lighter. My bike does 0-100 in 10 seconds N/A @ 40 MPG... I don't need another 200HP in the Z. What is so hard to understand about other people not wanting what you want?
