Clutch Burnt Smell!!!
Old Feb 2, 2004 | 06:48 PM
Loic's Avatar
Loic
Angry Clutch Burnt Smell!!!
Something really strange just happened with my clutch. When the clutch is hot, basically when I do stop and go in LA traffic or when I launch the car pretty hard from a dead stop, I get a really strong burnt smell inside the car within few seconds; It was some bad onetime that I had to pull on the side of the road. But when I get out I cannot really smell anything….the smell is only getting out of the vents of the car!!! How is that possible??? The car is only 3k miles, and I drive the car quiet conservatively….I never liked the feel of this clutch, I get lot of feedback from the pedal and the clutch is kind of noisy when it engages. Does anybody experience similar issue…
On a technical point of view, I cannot understand why the smell would come out of the vents… Any ideas???
Old Feb 2, 2004 | 07:05 PM
westpak's Avatar
westpak
SFZCC
I don't know if this is your smell, but I get a heavy smell when I do hard accelarations but I think it is exhaust smell which odly is coming inthe cabin, maybe it is the cats.
Old Feb 2, 2004 | 07:55 PM
Loic's Avatar
Loic
Angry
It doesn't really smell like exhaust gas but definitely more like something is burning and it seems to be related to the clutch…
Old Feb 2, 2004 | 08:19 PM
Azn03Z's Avatar
Azn03Z
smell like rubberish?
its probably related to the cat.
Old Feb 2, 2004 | 08:51 PM
Loic's Avatar
Loic
Unhappy
Yes it smellt like rubberish...
But how come the smell get inside the vents...
And why the cat is smelling like that......
Old Feb 2, 2004 | 09:15 PM
Psyc0's Avatar
Psyc0
I have the same smell... wtf is it? I find every time i drive hard i wind up w/ the smell in the cabin, it was really bad one time, I had to open all the windows and drive around for a whiel to get it out of the car... it sucks
Old Feb 3, 2004 | 09:03 AM
Loic's Avatar
Loic
The smell I'm geting might be different, because I get it only when I use the clutch heavily. If I only drive the car hard but never do a steady start, I have no problem. If I do some hard start or get stuck in bad traffic, I'm getting this nasty burnt smell...
Old Feb 3, 2004 | 09:25 AM
Jsn350Z's Avatar
Jsn350Z
I have never herd of any smell other then for the first couple hundred miles and that is your exhaust, but soon goes away.
I am willing to bet that you are just slipping the clutch out to much and your burning it... If it is THAT strong its the clutch.
You should work some faster clutch work and not letting it slip so much.
As for the noise, yes it is very loud when it is going into gear, and this is normal.
Old Feb 3, 2004 | 10:01 AM
Azn03Z's Avatar
Azn03Z
Yes, you'll get that when you drive the car hard, i guess its burning off something in the engine, because i got that smell in my 98 Accord, 03 Lexus ES300 as well. It'll go alway after sometime of driving the car.
Old Feb 3, 2004 | 04:29 PM
Loic's Avatar
Loic
You might be right but I'm not working my clutch that hard, I use my car as a commuter not a race car...I've being racing car in Europe for years, so I guess I know how to handle a clutch...
But still, why is the smell only present in the cab ???
Old Feb 3, 2004 | 04:35 PM
Jsn350Z's Avatar
Jsn350Z
I trhink you need to determin if it really is a clutch smell. I think it is pretty hard to mistake it with another smell.
Old Feb 3, 2004 | 04:43 PM
zand02max's Avatar
zand02max
I have 1900 miles and I get the smell in the cabin also, However, I don't think it is coming from the clutch, because it smells when I start the car up.
My smell is like radiator fluid, however i have no leaks either. And of course the dealer is clueless, they want the car for the whole day.
My smell gets worse when I turn the heater on, ect.
Old Feb 3, 2004 | 05:16 PM
Jsn350Z's Avatar
Jsn350Z
Hmmm.. I have NO idea what smell everyones talking about... There was a smell fomr the exhaust/engine but only for the first few hundred miles and that was just the parts breaking in.
Old Feb 3, 2004 | 05:32 PM
zand02max's Avatar
zand02max
I had that exact smae smell when I first got it. That went away after a few days after it was broken in after a few hundred miles.
However this smell, that I have is totally different.
I used to own a 1982 Crown Victoria and I had my heater core busted, hence it smelled like radiator fluid.
My Z has the exact same smell. I wonder if its the heater core inside the car. Anyone?
Old Feb 3, 2004 | 05:42 PM
Jsn350Z's Avatar
Jsn350Z
Hmm, intresting.. Seems quite a few people smell it too..
Old Feb 3, 2004 | 05:48 PM
zand02max's Avatar
zand02max
Does anyone else have the same smell I do. Radiator fluid type smell coming from the vents?
Old Feb 3, 2004 | 05:58 PM
JeepRage's Avatar
JeepRage
Funny, I just really took notice of the smell tonight getting out of my car (thought I smelled a little something before, but actually acknowledged it tonight). When i opened my door to get out of my car, i smelled a clutch/rubber smell. I usually drive a LITTLE harder just before i get home, but this just means quick 0-45 mph from the stop sign, and then nail it 2/3's of the way in third again to hear the intake/exhaust, not dropping the clutch.
I havent really noticed it inside the car, just when i get out. It doesnt smell like extreme burnt clutch or tires, but almost like a mix of the two.
Hall
Old Feb 3, 2004 | 06:03 PM
yobri's Avatar
yobri
The smell fairly frequently. Figured it's normal.
Old Feb 3, 2004 | 06:27 PM
Loic's Avatar
Loic
Unfortunatelly it is pretty difficult to describe a smell....
Talking about the clutch, I've been reading all over this forum that the clucth is pretty noisy but do you get some bad feedback in the pedal (vibration, shakes) while you're clutching and/or just before the clutch engaged ??
Old Feb 3, 2004 | 06:28 PM
Loic's Avatar
Loic
Normal ?! when the smell is so bad that you have to get out of the car!!!!
