08 350z I need to know where the coolant temp sensor is plz help
Old May 9, 2014 | 03:16 PM
Blackcobra's Avatar
Blackcobra
Default 08 350z I need to know where the coolant temp sensor is plz help
I had my fan jam and I didn't know my car overheated I turned it of once I saw it changed the fan and the 2 fuses that blew but know my fan stays on I want to change that sensor or if u know what it could be plz help and if u have a pic or diagram how to get to it plz I have the hr engine
Old May 9, 2014 | 10:15 PM
winchman's Avatar
winchman
It's on the coolant pipe that goes across the back of the engine. It's 22630 in the upper right hand corner of this diagram.
I'd be more inclined to look for a stuck relay before opening up the coolant system. If you don't bleed it correctly, you're going to have some other problems.
You can/should download a service manual to help you figure out where the problem might be. You should also check for any codes on the ODB port.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
pslamp32
Feb 8, 2017 09:07 AM
350Z Project X
Oct 17, 2015 05:16 PM
RyansZ33
Sep 15, 2015 05:54 AM
