350z 2004 roadster door swap
Old Nov 5, 2014 | 06:37 AM
callia6's Avatar
callia6
Default 350z 2004 roadster door swap
Anyone have a DIY on how to remove a 350z driver side door and replace it with another one? Like where all the screws and bolts are, and tips on installing it.
Old Nov 5, 2014 | 08:22 AM
MyLilZ's Avatar
MyLilZ
It pretty easy,pull fender off 2 bolts at bottom,3 on top of fender 2 under corner of front bumper by headlight.They are all 10mm. First you need to pull the side skirt off I think their are 5 10 mm bolts holding it on and five clips like the ones that hold the door panel on.You can use a screwdriver and a rag to protect the paint to pop them off.I had a small pick of two sided tape at the rear of the door jam under mine where the back of the door is .Then just undo the power cable for door locks/ power windows.4 blots hold door on 13 mm.Takes about 45 minutes to change out doors
Old Nov 9, 2014 | 03:03 PM
milto0n's Avatar
milto0n
^ Thanks for this info. I too have been wondering how to replace a door but searches always come up short.
416blueZ
Sep 25, 2015 10:00 AM
hardkicks
Sep 20, 2015 12:28 PM
CJs_Z33
Sep 18, 2015 12:06 PM
Suffolk350z
Sep 13, 2015 02:43 PM
