Drive my 350z????
Old Jun 12, 2015 | 03:24 PM
CodyWade92's Avatar
CodyWade92
Default Drive my 350z????
Would any experianced z owner in the DFW area be willing to drive my car? I'm new to owning a z and i seems like I may have a clutch and or flywheel issue, every now and then when I'm shifting it seems like my clutch is returning very slowly almost a sticky feeling, but then again I'm not a z/manual expert by no means. So if anyone has any info please help me out, or if you are willing to give it a test drive and see what you think?
Old Jun 12, 2015 | 03:30 PM
terrasmak's Avatar
Post this in the regional section please
Old Jun 12, 2015 | 03:53 PM
oldschool350z's Avatar
oldschool350z
Master or slave cylinder issue
Old Jun 12, 2015 | 04:01 PM
CodyWade92's Avatar
CodyWade92
Is that expensive to fix, and how exactly would I check that?
Old Jun 12, 2015 | 06:31 PM
terrasmak's Avatar
Master is simple, slave depends on the year of your car. 03 to 06 is beyond simple , and 07/08 is a pita
Old Jun 12, 2015 | 07:24 PM
Cookiezor's Avatar
Cookiezor
have u tried bleeding the clutch(before u do, take old fluid out from the cylinder with a turkey thing or a syringe) ? when u say clutch u mean the pedal is sticky right? I remember there is a recall on slave cylinders, u should call the dealer and let them check ur vin to see if ur car got affected by that
Old Jun 12, 2015 | 11:08 PM
CodyWade92's Avatar
CodyWade92
Yes the peddle and I will have to do that
Old Jun 13, 2015 | 04:16 AM
Fridge Gnome's Avatar
Fridge Gnome
Are you at high revs when this happens? Mine will come up slowly if I'm in 1st and I let the rev get too high.
Old Jun 13, 2015 | 02:14 PM
Frank_White's Avatar
Frank_White
what year is your Z?
Old Jun 14, 2015 | 04:58 AM
Toneloc's Avatar
Toneloc
This is your answer
End thread
Old Jun 15, 2015 | 05:18 AM
PerfZ's Avatar
PerfZ
Bleed first, with hi-temp Motul or something similar. If that doesn't work then master and slave. Do them both. My '03 has original master, slave, clutch and tranny. 149,000 miles.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
