Future of the 350Z
Old Sep 17, 2002 | 11:35 PM
___DJK___'s Avatar
___DJK___
Dont worry, thats been done in like 100 posts already. Welcome ot the site.
Old Sep 18, 2002 | 01:19 AM
Da Gimp's Avatar
Da Gimp
Thanks for posting that, interesting stuff.
Old Sep 18, 2002 | 04:15 AM
rai's Avatar
rai
Very well thought out. I'm not sure of the source (honda troll) I mean is he for or against the Z??
Anyway I think I can see the logic behind his conclusions. I am only interested in non forced induction mods. I was only thinking of a 10-12% gain so 320 sounds good to me. (I was not expecting to get M3/S2000 type hp per liter).
320 hp is good for 10 pounds per hp.
Old Sep 18, 2002 | 05:42 AM
Habiib's Avatar
Habiib
I'm on the same boat, trying to pick between the 350z and S2000 or G35C, but I'm going to wait until the Z drivers get more seat time (...like 4 months) and then ask to give me their impressions of their car (pro and con). Because there is no way I can get any good info on a car based on a test drive so that's not an option.
Off Topic:
I believe that Nissan has achieved more HP out of the VQ35 than what the Z currently has, but they lowered the number a bit to leave room for future HP increases as the model year goes up. I'm praying that one day they go towards a VQ35VE or bring the VQ30DET over and put it in one of their cars.
Old Sep 18, 2002 | 06:04 AM
S2kRob's Avatar
S2kRob
I know this guy. He really knows his stuff. I'm not sure I agree with everything he says about the VQ but he makes some valid points.
If you look at the dyno's, the torque on the VQ falls away rapidly. Why is the big question. If you can boost the torque in this range, horsepower will rise considerably as well.
Stay tuned the aftermarket is already working on it.
For comparison, cams and a co-ordinated chip in my VR6 Corrado gave me an extra 1000rpm of usable power, which was much appreciated.
JDZ,
Not to turn this into a pissing match, but you don't know what you are talking about when it comes to the S2000. The torque is very flat, with a jump from a low plateau to a high plateau at the VTEC engagement point. It's low compared to the 350Z, but peaky it isn't.
Old Sep 18, 2002 | 06:06 AM
rai's Avatar
rai
Originally posted by ohio_z_man
Regardless of what type of car this person is for or against is irrelevant. This person seems to understand engines and the capacities that they possess.
It is not irrelevant. If he is against the Z he could be making up things or putting a bad face on the facts to make the honda look better by comparison.
Just because someone "seems to understand" something doesn't mean it is a fact.
Old Sep 18, 2002 | 07:00 AM
S2kRob's Avatar
S2kRob
BTW, that post was made on an S2000 board, so you have to take it in that context. If he was posting here, he would have put a more pro Z slant to it. I personally would like to know what boltons can add 20hp to my S2000. I don't think there are any.
Old Sep 18, 2002 | 07:12 AM
Chris S's Avatar
Chris S
That post was made by "Ultimate Lurker", who has an unsurpassed reputation on S2ki for his throrough, accurate, and unbiased knowledge. He doesn't strike me as showing bias towards one brand or model, but tells the facts as he sees them.
If there's anyone I can count on for good info there, it's him.
Old Sep 18, 2002 | 07:38 AM
Them Bones's Avatar
Them Bones
"In order to facilitate higher revving, you'd need to replace the cams, which would almost certainly compromise the low end performance since the Z does not use a variable profile/lift setup like VTEC. "
Um, the Z has continuously variable valve timing (CVTCS).
Throttle body, intake, cam mods should be able to move some performance from the low end to the top end, if that is what you want.
-TB
Old Sep 18, 2002 | 08:39 AM
importriders's Avatar
importriders
Default 20 WHP!!!
Yeah, after I read 20WHP from "bolt ons" that post lost all validity in my mind. 20 more HP at the wheel is a huge gain from bolt- ons, especially when you're taking about a Honda S2000. Don't you think Honda's engineers would have seen that.
Old Sep 18, 2002 | 08:46 AM
S2kRob's Avatar
S2kRob
Them Bones,
Continuously variable cam timing is different than VTEC. VTEC changes the actual cam profile, so you can run a mild cam for low revs and an aggressive cam for high revs.
Variable cam timing just rotates a single profile cam in relation to the exhaust cam, but does not change the actual cam profile, so you can't install a big hairy race cam like you theoretically could on a VTEC engine and expect it to idle properly.
BMW will be releasing a fully variable lift and timing system in the next couple of years. That will be a real breakthrough engine.
Old Sep 18, 2002 | 09:10 AM
NissaNZ's Avatar
NissaNZ
I'm sure the Nissan engineers can get 350hp at the crank without FI. By the way is the guy talking about 320whp or 320hp max?
Old Sep 18, 2002 | 09:36 AM
rouxeny's Avatar
rouxeny
I thought that it was quite difficult to improve on the S2000 engine, seeing as it comes out from the factory pretty well tuned. I don't know of any simple mods that add 20 hp. The best, but also most expensive, add on is the supercharger, made by Comptech (I think). I read somewhere that many of the typical mods (intakes, headers....) did not offer much improvement.
The VQ hopefully has a lot more potential. I frimly believe that Nissan will come out with a more powerful version within a year or two. They have to, in order to compete with the new Supra, RX-7, etc.
