Wierd starting issue.
Old May 17, 2016 | 10:37 AM
Thesquatch350z's Avatar
Thesquatch350z
Default Wierd starting issue.
So i recently bought an 03 6-speed 350z. The previous owner basically never drove it and it sat in a garage, so i thought "great" a nice car i can enjoy as a replacement for my crappy old honda. But since i got it home it hasnt started.
When i turn the key all the gauges go off except the service/oil/battery lights. All i can hear is a click from somewhere under the dash. I was only able to start the car via bump starting when i got it inspected a few days later.
I asked the previous owner about it and he said it has always been fine for him except the clutch switch was a bit junky sometimes. So i ended up getting a new battery and new clutch switch but it still does the same thing. I cleaned up the battery terminals and the connection on the ground wire too. I check through fuses inside and in the bay but none of them seem to be blown.
Anyone know what might be causing this?
Old May 17, 2016 | 11:55 AM
mikeh22's Avatar
mikeh22
The clicking in the dash I assume is the relay that should send signal to the starter. See if you can get at it and check if its actually send 12v out when actuated, if it is working I would look into the starter. The car also needs a signal from the fob I believe to start as well.
Old May 17, 2016 | 12:05 PM
rustyschopshop's Avatar
rustyschopshop
When you installed the clutch switch did you check the little plastic stoppers. One of those could be broken not allowing the switch to work.
Old May 17, 2016 | 12:07 PM
rustyschopshop
Figured I would take the last comment alot further and pull some picks from my build thread. These are what I am refering to.
Old May 17, 2016 | 03:40 PM
Thesquatch350z
I tried pushing the switch in all the way by hand and tried shofting the switch connectors. Still nothing. Ill have to give the relays another check.
Old May 17, 2016 | 03:43 PM
Thesquatch350z
From the fuses inside the car i didnt see any blown. The car had a bad aftermarket alarm that i pulled out, thinking that was the issue, but nothing has changed. Ill give the relays and fuses another look.
Old May 17, 2016 | 04:49 PM
travlee's Avatar
travlee
Master
i wonder if it had a starter bypass, most do, and for some reason it is killing the input to the starter still ....
Old May 17, 2016 | 06:27 PM
Thesquatch350z
Would that cause the dash and gauges to cut out as well?
Old May 17, 2016 | 06:30 PM
travlee's Avatar
travlee
Master
I wouldn't think, but might be secondary from it....
Old May 18, 2016 | 11:17 PM
phreaktor's Avatar
phreaktor
Design Engineer
Awesome to see people helping out a new guy....
Old May 19, 2016 | 03:55 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Where are you in Mass? I would get a friend and a multimeter and see if your getting power down to the starter when you turn the key, if you have power your starter probably needs replacing. If not then its probably a alarm issue... Hook that back up, start tracing wires or bring it to a shop.
Old May 19, 2016 | 06:30 AM
NissanTracker's Avatar
NissanTracker
Ahh, some other Mass guys. I'm in the Lowell Area.
Old May 20, 2016 | 01:20 AM
Thesquatch350z
It was a blown fuse. Car is fine now. Its always the little things
Old May 20, 2016 | 07:17 AM
Arrtus's Avatar
Arrtus
Yay, enjoy your Z!
Old May 27, 2016 | 02:17 PM
winchman's Avatar
winchman
Which fuse was blown?
Old Jun 7, 2016 | 11:23 AM
drew-p-bawlls13's Avatar
drew-p-bawlls13
I know how you can turn it on whenever mine is doing the same thing
Old Jun 7, 2016 | 11:29 AM
travlee's Avatar
travlee
Master
OP hasnt logged in going on 3 weeks,
plus he said he fixed the issue...
CUL8ER
Engine Swaps
May 4, 2016 10:34 AM
HoBrahYouStink
May 1, 2016 05:31 AM
Smokey Bear
Apr 29, 2016 06:08 PM
IridiumCore
Apr 27, 2016 08:18 PM
Spankmetwotimes
Apr 19, 2016 01:51 PM
