ABS slip and tcs lights don't work
Old May 23, 2016 | 05:56 AM
Harden's Avatar
Harden
Default ABS slip and tcs lights don't work
Hi, I have a 2004 350z enthusiast package and the problem is that the tcs abs and slip lights won't illuminate on the gauges when I start it and drive it. I tried to push the tcs button but nothing happens. The switch itself does light up but when I press it it doesn't turn the tcs off. Do you guys think it is in the control unit? If you guys could point me to the right direction I would appreciate it. Thank you
Old May 23, 2016 | 06:00 AM
travlee's Avatar
travlee
Master
dealer for diagnostic
/thread
Old May 23, 2016 | 06:11 AM
Harden's Avatar
Harden
/thread
I'd rather not take it to a dealer. if this is something that I can fix or buy a part for I'd rather do that. But if not it's not a big deal.
Old May 23, 2016 | 01:42 PM
Sleepiedaze's Avatar
Sleepiedaze
did you check your fuses, power to switch, rear diff bushings? any error codes when doing a scan? has it ever worked?
have you pulled the cluster out to see if voltage is getting to that portion of the board?
Nabice
Aug 19, 2016 08:13 AM
mechanicaljesus
Apr 4, 2016 04:41 PM
350z_Gio
Suspension
Mar 23, 2016 05:51 PM
04grayz
Mar 15, 2016 04:19 PM
04grayz
Mar 14, 2016 05:56 PM
