maintnence help :)
Old Sep 12, 2016 | 08:43 AM
newbienismo's Avatar
newbienismo
Default maintnence help :)
I'm going to be changing all the fluids on my 2008 350z nismo I will have it on a lift
What else should I do while I have it on the lift to kill 2 birds with one stone.
Does anyone recommend what fluids I should be using for my car here is a check list of what I plan to do oh and car is a nismo with 62k is there anything else you (veterans would recommend)
oil/filter
clutch fluid
transmission
change air filters
Old Sep 12, 2016 | 09:11 AM
travlee's Avatar
travlee
Master
rear diff
Old Sep 12, 2016 | 09:43 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Change the bushing its super fun.
Old Sep 12, 2016 | 11:45 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
oil/filter
clutch fluid
transmission
change air filters
Your choice 5w-30 synth oil & filter
Clutch.... ehhhhh, unless it's never been changed, leave it.
Trans
- Redline MT85-recommended due it having the proper friction modifiers necessary for Nissan 6MT (CD009 in your case) OR Nissan factory gearbox oil.
Rearend (as mentioned above)
- factory Nissan GL-5 75-90 spec or other good synth like Redline, Lucas, etc.
Visual inspection of all bushings (look for leaks on diff bushing and check tightness of all others)
Old Sep 12, 2016 | 01:06 PM
dkmura's Avatar
dkmura
General & DIY Moderator
I'd also suggest you consider two other items: First, bleed all four brakes with fresh DOT 4 brake fluid (ATE Super Gold or the like). Second, unless you have service records showing it was recently changed, a fresh flush and fill with antifreeze/distilled water makes sense for a Colorado Z.
Old Sep 12, 2016 | 01:55 PM
JBJ's Avatar
JBJ
And then make sure you come to the NASA weekend at Pueblo in October.
Old Sep 12, 2016 | 05:10 PM
NissanTracker's Avatar
NissanTracker
Usually when I have my 07 Nismo up, I do a visual inspection of control arms, tie rods and make sure there are no torn boots. Check rear drive axle boots as well from the pumpkin. Replace clips/retainers for the engine splash guard underneath. I'm crazy sometimes... I also use a semi-rough brush and clean wheel well areas. I hate when there is dirt/mud in those creases.
Have fun !
Old Sep 12, 2016 | 09:34 PM
newbienismo
Thanks for all the support you guys
Also I was wondering if this is normal,If I'm rolling in first gear in stop light traffic and have to stop fast,and I press the clutch in a little fast I hear a loud clunk noise same thing happens if I press it in fast to shift to second sounds awful like the entire trannies falling out anyone know what it could be.
SirMichael
Oct 31, 2016 10:14 AM
CK_32
Sep 20, 2016 07:02 PM
mrwhite
Sep 12, 2016 01:50 PM
nizmo_0385
Suspension
Sep 12, 2016 07:20 AM
mazzotta.al
Sep 7, 2016 05:32 PM
