Trunk light not working
Old Oct 3, 2016 | 08:47 AM
sjtomcat's Avatar
sjtomcat
Default Trunk light not working
I checked the fuse for it and the fuse is still intact and not blown. I thought maybe the light bulb was out so I ordered a knew bulb and still not working. Maybe something internally with the wiring? Not sure what else could be the problem.
Old Oct 3, 2016 | 09:07 AM
travlee's Avatar
travlee
Master
invest in a test light
Old Oct 3, 2016 | 10:39 AM
absurdparadox's Avatar
absurdparadox
A few things.
Wiggle the bulb around and make sure it is just not fitting poorly.
Your new bulb could also be bad, something to consider.
You can use a volt meter on the plug and see if you are actually getting voltage.
Old Oct 3, 2016 | 11:54 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Also its a trunk light, who cares if it works?
billybronco1
350Z Roadster
16
Oct 12, 2016 08:41 AM
JoeJoe13
Oct 10, 2016 07:39 PM
adam.inbody
Oct 1, 2016 04:02 AM
jaguar3407
Sep 30, 2016 04:45 AM
adam.inbody
Sep 26, 2016 03:36 PM
