new fuel pump new problems help!!
Old Oct 21, 2016 | 10:41 AM
Sup Fresh's Avatar
Sup Fresh
Default new fuel pump new problems help!!
Hey guys been lurking here for a while finally going to post something and of course it's a problem. I just recently installed a new fuel pump(yesterday) and it drove fine for a quick trip around the block but now it's rough to start and idles very rough. It hesitates when I give it gas any ideas what could be causing this?
Old Oct 21, 2016 | 02:14 PM
venture210's Avatar
venture210
http://www.christurnbull.com/project...-g35-fx35-etc/
Assuming the pump is larger than the stock one, you probably didn't drill out the regulator orifice and the swirl jet.
Edit: You probably have to alter your fuel tables in whatever software you are tuning with. Likely running rich since the pump is designed to flow more fuel
Old Oct 21, 2016 | 04:04 PM
Sup Fresh's Avatar
Sup Fresh
Its actually an oe fuel pump on a mainly stock car which is why this is especially puzzling
Old Oct 22, 2016 | 03:40 PM
venture210's Avatar
venture210
have you tried cleaning the filter and injectors?
Also, if you want another pump to test, I have my oem one sitting around if you want it. PM me if interested
